Thread: Hayward Skimmer [Floating] Weir
    Houston, TX
    1,102
    Hello to all,
    Our Hayward skimmer floating plates [or pool floating weirs] on one of the skimmers keeps coming off and out into the pool area. These do not have spring loaded hinges. They are installed by pushing in the circular hinges flush w the skimmer weir, then after placing the weir in the correct position of the skimmer inlet, you push out on the hinges and they go into the sm hole. Yuu then push-up on a piece of sliding plastic that is supposed to lock the hinge piece into the two sm holes into the skimmer body.
    Does anyone have a recommendation on a good make/model replacement that is either spring loaded or something that keeps the skimmer weir in place? Ours is a light tan color so I need to match the color too.
    As usual, thank you very much for your help and advice,
    tstex
    InGround 15K gal, 18'x30' 3.5' to 5.5' depth w/ 9'x9' spillover Spa, Pebblesheen w/ Travertine, Hayward 3 HP VSP, Hayward C4030 Cartridge, Hayward 1.5 HP for 2 Scupper columns, ProLogic, PL-PS-8 Panel, Hayward H400FD 400K BTU Heater, 3 ColorLogic LED, Spa Blower, TF-100 w S-Stick, QC Tiger Shark, Autofill If you enjoyed your TFP experience, please consider donating to Support TFP!
    Jun 2015
    Wildomar, California
    423
    Re: Hayward Skimmer [Floating] Weir
    All of the floating skimmers work the same, they occasionally fall out. The skimmer originally came with a weir plate. They can be purchased at a pool store or online
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    426
    Make sure there is not any cement or grout hindering the locking in place of the weir.
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    poolside@haywardnet.com
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    You can find many generic weir doors on amazon around 15 bucks.
    measure yours for a replacement...I replaced mine with a spring loaded one and I think I did see them in tan color.
    Dolphin E10 Cleaning Robot.
    Houston, TX
    1,102
    Quote Originally Posted by borjis View Post
    Thanks
