Thread: Does anyone else take out filter grids when going on vacation for a few weeks?
    Jul 2014
    Berks County, PA
    206
    Hi,
    As sort of a corollary to another thread I posted...does anyone do this? I always remove the grids just for peace of mind to not have to worry about filter pressure increase while away with noone to take care of it. Also, over the years I often experienced rather unpredictable and short cycles. So far this summer, though, I have a really long cycle going (almost a month) which I think might be attributable to the replastering I had done last summer and also better chemical maintenance. My cycles are always a bit erratic after opening until the pool gets cleared up, then seem to be fairly constant but historically have never gone much more than 2 weeks without a gradual or sometimes sudden increase. Based on this cycle it seems that it would be fine to backwash, clean, recharge, and let it go while away. It would be nice to come home to a pool that looks as good as it does before leaving, but then there is always that uncertainty. Peace of mind is worth something too. Any thoughts from others? Perhaps I'm the only one who worries about this sort of thing (?) I realize that without the grids I'm basically just circulating water, albeit at good, constant pressure, so that seems to help keep the water looking pretty decent by the time I return home.
    Keith
    12,000 gal. Anthony IG pool; 3 ft. shallow end to 6 ft. deep end; Built 1989; Renovated July 2014 using a 10-part unexposed quartz plaster aggregate of 3 S-grade Blue, 3 S-grade Gray, 2 T-grade Blue, 2 T-grade Gray; Apollo VA-52 DE Filter; Hayward SP-2607X10 Super Pump 1-HP Single Speed; Jandy AE-Ti Heat Pump; Taylor K-2006 Test Kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Re: Does anyone else take out filter grids when going on vacation for a few weeks?
    I go about 9 months between backwashes, so no, I've never done that. Why does your filter clog so fast? Are you next door to a farm or a quarry or some other source of dust?
    I just raise the water level a couple inches above normal and stuff a floater with pucks and go.
    Jul 2014
    Berks County, PA
    206
    Surrounded by farm fields on every side of our property. Also, we use baquacil which apparently is known for filter issues
