Thread: Is my DPD powder still good?
    May 2013
    Long Island NY
    419
    my DPD powder (0870) is turning a shade or 2 on the gray side. I assume this is just because of moisture getting to the powder. It's still usable isn't it?
    19,000 gal - Vinyl IG - Sand filter -1.5hp. - Taylor k 2006 - Loop Loc cover
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: Is my DPD powder still good?
    Yes, that is normal..
    May 2013
    Long Island NY
    419
    Thanks!
    Mar 2007
    San Rafael, CA USA
    12,082
    See the Taylor article on Recognizing a Compromised Reagent that says:
    As it degrades, the color will turn from an off-white color to gray or purple-gray and will gradually become a purple-brown color.
    The gray is OK, but when it starts to get purple and especially purple-brown it needs to be replaced.
    May 2013
    Long Island NY
    419
    Ok, thanks chem Geek, I think I'm good then. I had bought some more at the start of the season and put the gray color stuff on the shelf. I think I will go ahead and use it up before it turns purple.
