Thread: Is weir door doing its job
    Jul 2015
    Lakewood, CA
    12
    I asked about the necessity of the weir door the other day. Just installed and it appears the water is coming through the opening of the pool at the same speed, but is gushing to the skimmer/skimmer basket (like a toilet being flushed), so the water is never able to rise in the skimmer. I assume this means the door is increasing the flow rate as it is supposed to?
    Roman in ground pool (16 x34, 20,400 gallons), cleaned professional every Tuesday, with a leaf skimmer, suction cleaner connected to skimmer via hose and brush. Pool pump is currently set for 6am-1pm daily. Pool is filled with a water hose two times/week for about 40 minutes (my understanding is filling pool isn't under restrictions by my city).
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,565
    Re: Is weir door doing its job
    Just make sure it isn't sticking and your water level is high enough. 1/2 to 3/4 up the skimmer face....(I keep mine higher).
    30,402
    Well, yes, but I don't like hearing you say it is gushing. Water level should be roughly halfway up on the skimmer throat and no gushing......just a steady flow. Is your water level too low?
    You should keep your posts under one thread so we can see your "whole story"
    Jul 2015
    Lakewood, CA
    12
    Thanks! Will keep under one thread in future. Water level raises about halfway up on the skimmer throat, then lowers. It's the lowering that makes the sound I described as "gushing." Maybe steady flow is better description. Sorta looks like a little waterfall. I think the water legal is fine - it's about halfway up the side opening.
