Results 1 to 20 of 20
Thread: Sodium dichloro-s-triazinetrione dihydrate = dichlor?
    Jun 2014
    Kent, Ohio
    46
    I bought a bucket of chlorine and what I got is labeled Sodium dichloro-s-triazinetrione dihydrate granules. When I use http://www.thepoolcalculator.com, there are several drop downs. The one I'm using that looks the closest is Dichlor. There is not a percentage on the drop down, although the bucket says 56% available chlorine. Am I using the correct drop down?
    Thanks
    26' X 45' peanut shaped 42,000 gallon non- SWG polished marble (Hydrazzo) IG outdoor pool 5/2014.
    Pentair Intelliflo 3HP variable speed pump. Pentair Clean and Clear Plus cartridge filter
    Pentair Ultratemp heat pump
    Pentair model 320 chlorine feeder. Ultra Pure Ozonator. Pentair Easy Touch.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,462
    Re: Sodium dichloro-s-triazinetrione dihydrate = dichlor?
    Dichlor is the right stuff. It is all the same.
    Mar 2007
    San Rafael, CA USA
    12,082
    There are technically two types of dichlor: anhydrous and dihydrate. However, pretty much the only one you see available is the dihydrate and that is what PoolMath assumes. The dihydrate is 55% Available Chlorine while the anhydrous is 64%. Usually the product concentration of sodium dichloroisocyanurate aka sodium dichloro-s-triazinetrione is 99%.
    By the way, you should be using PoolMath and NOT The Pool Calculator since the latter is no longer maintained (it was sold to a company that stopped maintaining it so we use PoolMath instead that has some bug fixes and some additional features).
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    When you use poolmath , plug in your pool size and your numbers and then scroll down to Effects of Adding Chemicals. Put in the dose it recommends of dichlor and see what you're doing to the CYA and the pH. See what the whole bucket of Dichlor will do to your pool chemistry. If you have hard water and no CYA, maybe it's a good choice. If your CYA is already in range, or high, you'll be making things worse.
    Jun 2014
    Kent, Ohio
    46
    Thanks for the heads up on Pool Math, and also on the Dichlor.
    I know we went through this last year, and due to the fact that I drain the pool annually, it is pretty easy for me to use Dichlor, and TriChlor pucks in the auto feeder. As I get close to the end of the season, nad my CYA gets above 60, what is my alternative for chlorine without adding CYA? Is liquid bleach it?
    Thanks again!
    Richard320's Avatar
    Jan 2010
    18,967
    Quote Originally Posted by ltfdrebbin View Post
    Thanks again!
    Bleach leaves nothing but salt behind. Cal-hypo raises CH, which may or may not be a bad idea depending on test results.
    Jun 2014
    Kent, Ohio
    46
    I'm struggling with low CH. I've added 75 pounds of calcium chloride already this year, so maybe I'll get some Cal-Hypo instead of all those gallons of bleach.
    I just played with the "effects" portion on the bottom of pool math. Good stuff.
    Thanks!
    DFW, TX
    24,462
    Yes, cal-hypo is the perfect solution to chlorinate and add calcium.
    JoyfulNoise's Avatar
    May 2015
    13,179
    Agreed. Since you drain and refill seasonally, you could easily start off with dichlor, then switch to using bleach and/or cal-hypo (not at the same time though) once your stabilizer level hits 40-50ppm. Your situation is one of the few times that trichlor/dichlor/cal-hypo makes sense to use for regular pool chlorination.
    Good luck.
    Matt
    Mar 2007
    San Rafael, CA USA
    12,082
    Do you mean you do a partial drain below the returns for winter closing or do you mean you completely drain your 42,000 gallon pool every year?
    Jun 2014
    Kent, Ohio
    46
    I completely drain the pool every year.
    Jun 2014
    Kent, Ohio
    46
    Good luck.
    Planning ahead for next year- you say not to use bleach and cal-hypo at the same time. Could you please define same time, and how I old use these together?
    Aug 2014
    Northern IL
    4,615
    I am wondering why you drain your pool. Do you worry about snow melt, freeze damage, cost of new water, etc.?
    May 2015
    13,179
    Sent from my iPad using Tapatalk
    I meant to not mix them in the pool together. You could switch between them on a daily basis. One other method would be to start with dichlor and use that until your CYA hits 50ppm. Then switch to using cal-hypo until your calcium hardness hit about 350ppm. Then, finish the season with bleach.
    Honestly, I wouldn't even bother with the cal-hypo because I'd prefer to use bleach but many like it the convenience of the powdered form.
    As long as you maintain the proper FC/CYA ratio and you keep your water balanced and within the recommended ranges, then you can use whatever form of chlorine suits your needs. The point of the TFPC Method is to know what the effects of adding chemical are on your water and to apply that knowledge to keep your water balanced and properly sanitized. Most people with pools don't have the flexibility you seem to have with annual water exchanges, so that is why folks don't use some types of chlorine
    Matt
    domct203's Avatar
    Jun 2015
    CT
    3,577
    It's your pool, I'm not to judge, but that seems like a waste of 42K gallons of natural resources annually.
    I'm also curious for the reasoning.
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    May 2015
    13,179
    Quote Originally Posted by domct203 View Post
    Dom
    Not to pile on the "don't drain your pool" crowd, but did the pool builder say you could do that?
    Typically with plaster pools (the Hydrazzo stuff looks really nice!), you want to keep the water in the pool to moderate temperature swings and maintain the water pressure against the plaster/pool surface. This is done to avoid cracking the plaster and floating your pool out of the ground. Do the CL Industries people say it's ok to drain it and leave it empty? Is your water table sufficiently low enough to handle the empty pool?
    Matt
    Jun 2014
    Kent, Ohio
    46
    This seems like great advice. Thank you.
    Jun 2014
    Kent, Ohio
    46
    I'm in the very small minority here, but my pool has 2 purposes. We swim in it for the 3 months of summer we (sometimes) get here in Ohio.
    It's full of snow and ice for 2-3 months.
    The leftover time is spent skateboarding in the pool.
    I'm constantly worried about floating the pool, and cracking. And to you, my coping probably looks terrible. To me it looks great.
    I talked to several other people that have used Hydrazzo before building it, and have a well point pump under the pool to keep the water out when it is empty.
    The water costs money, and the inevitable repairs will cost money, but we get tons more enjoyment out of the pool this way.
    Notice all of the skateboard parks around the country. Many of them have pools that never have water in them, and I've never heard of one floating. Nevertheless, I built it slightly differently, and stay concerned.
    May 2015
    13,179
    I grew up on Long Island and the temperatures are fairly well moderated there due to the ocean. Even then, the warm summer months are so short I never thought building a pool there was a very good idea. But folks do it and they love it so I say, to each his own.
    You have found an interesting use for your pool when it is just too cold out to be useful, so I say, good for you! I don't think I said anything negative about your coping. If you like the way your pool looks, then that's fine by me.
    So enjoy your pool/skate board park! Hopefully the water table stays low.
    Matt
  20. Back To Top    #20
    Jun 2014
    Kent, Ohio
    46
    I didn't take offense at anything anyone said.
    I just figure that most people would not like coping that is ground down, and brown from urethane spray.
    I'll post some pictures of the cracks and wear once we drain it again.
    I should also write an Intellibrite light review, as mine has seen more abuse than most ever will!
