Thread: Create 6 ft deep end with an expandble pool liner
    Jul 2015
    houston/texas
    3
    Hi,
    I'm currently picking out an agp and liner that would allow me to create a 6 ft deep end. Would any metal frame pool work? I'm on a tight budget and am considering an intex with a newport overlap liner. Any advice would be greatly appreciated!
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Re: Create 6 ft deep end with an expandble pool liner
    Not sure you can do the with the Intex type pools. I've seen it done nicely with the walled pools.
    R.J.'s Avatar
    Jul 2012
    Minneapolis
    82
    I don't think that would work, either. How would you attach the liner to the top rail?
    18 x 48 Intex Ultra Frame
    2500 gph cartridge filter
    Intex SWG
    Jul 2015
    houston/texas
    3
    What type of agp can be used to create a 6 ft deep end?
    Casey's Avatar
    SW PA
    10,448
    Hello Rose. You definitely can not use an Intex pool to accomplish what you want. You must use a hard sided pool like this...
    Mine is a Sharkline Venture. If you are going with a deep end, you should buy the biggest pool you can afford with an expandable liner. I bought my pool at poolsupplyworld.com.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    A friend bought a used oval pool (steel sided) and made a deep end. It was quite nice. I can't remember how deep he made it.
