Thread: Please help me find this tool
    Oct 2014
    DFW Texas
    78
    I came across this and I have done the process with a small handheld tool and I believe this is what needs to happen to my pool. However HOURS of internet searching has found NOTHING as far as a tool of this nature to use for the job... I have the pads, those are no problem... But so far the only options I have is to drain the pool and get on my knees with an angle grinder or to work with an air powered sander, which I can do underwater but it isn't powerful enough.
    polishing a pool finish - YouTube
    This would be perfect for what I want to do.
    7-10 year old In ground 20,000 gal, Aquabright ecofinish W/ Spa, waterfall and infinity jet, 60 sq foot DE filter, Single speed pump, Racer cleaner
    Jun 2015
    Ottawa/Ontario
    339
    Re: Please help me find this tool
    What do you want to do?
    90,000litre, IG vinyl, 1/2 HP Tristar pump, Sandfilter, Aquarite T-15 ASG
    20000 gallon, IG, SWG, Sand Filter, Hayward 1/2HP + Lorentz direct solsr PV pump
    Oct 2014
    DFW Texas
    78
    I want to hit the whole pool with a 30 grit pad. The areas I have done look amazing, like how the pool looked when new. The untreated areas are very sad looking and rough to the touch. The pad leaves a good loooking and smooth surface.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    It looks like this pressure washer cleaner,
    BUT... I think they made that tool using an air sander and turned it into a pressure water cleaner, if you look close and pause the video, they used duck tape and an exit hose for the water...
