Thread: Channel Drain Plumbing
    Jun 2015
    Florida
    74
    I need to plumb a 2" channel drain to the front yard. I figured I'd get the adapter I see sold online with the drain but that's not the case. Builder said you just stick piece of PVC in round bottom part and go from there. Anyone have experience plumbing these 2" drains? I was hoping to go from channel drain to 4" drain pipe.
    Jun 2015
    Florida
    74
    Re: Channel Drain Plumbing
    Nevermind, I have it figured out lol. A piece of 2" PVC slips right in bottom of channel drain. Then a 2" to 4" bushing and I'm good. Wish I knew how to delete a thread
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,050
    No, don't try to delete it. You've added to the store of knowledge here.
    JamieP's Avatar
    May 2011
    Waxahachie, TX (south of Dallas)
    1,135
    Stupid question, but here goes... How does the water get into the 2" PVC slipped inside the channel drain? Do you drill holes in the top of it?
    28,000 gallon freeform, Stonescapes Tropics Blue Minipebble with abalone, 3.5' to 8.5' depth. 2 skimmers, 5 returns, dedicated vacuum port, Dolphin Z5 robot. All Pentair equip: EasyTouch 8, IC60 SWG, VS pump, 520 Cartridge Filter, 3 Intellibrites, 2 Color Cascade Bubblers. TurboTwister Slide and 8' Salt System Jump Board. TF-100. My Jan-Mar 2016 build:
    Waxahachie, TX Owner Build - A race to beat the baby!!
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Isn't the channel the drain. All you'd need is a 2-4 coupler
    Jun 2015
    Florida
    74
    The channel (which should have a tilt to it) fills up then travels out the pipe. A correction though. With my 2" (width of channel) deco drain, it's a 1 1/2" pipe that slips in the end of it. Then, I put a 1 1/2" x 2" bushing, then a 2" x 4" bushing. Then, the 4" black drain pipe attaches to the 4" end of bushing. I hope I didn't confuse anyone. If I had to do it over, I would just insist the builder included the adapter made specifically for going straight from channel drain to 4" drain pipe.
