Page 1 of 4 1234 LastLast
Results 1 to 20 of 72
Thread: Any Pool Calculator feature requests for spring 2009?
    The ice on the pool cover is melting and swimming can't be toooo far away. That means that it is again time to turn my thoughts towards the spring Pool Calculator update. If anyone has any requests for features they would like to see in my Pool Calculator, I would love to hear them.
    The top item on my list from last year is to add support for different strengths of muriatic acid, ones other than 31.45% - 20° Baumé. The problem is that I don't know what other concentrations it comes in, 31.45% - 20° Baumé is all I run into around here.
    Please tell me what you would like to see added. I can't promise to put in everything, but I do have a couple of days free for adding features and not much on my list to keep me busy.
    Thanks
    JasonLion
    Guest
    Re: Any Pool Calculator feature requests for spring 2009?
    How about an "autotest" feature where Jason comes to your house, tests your water, and plugs the results into the calculator for you? I think that would be one handy-dandy feature to have!
    (And maybe an "autodose" feature where he puts in the needed chems to balance your water!)
    (i'm probably gonna get banned for this one! )
    Quote Originally Posted by waterbear
    Hum, that could be done, but then I wouldn't be able to give it away for free anymore
    meatloaf's Avatar
    Feb 2008
    Gilbert AZ
    373
    Is it possible to make a Hot Tub calculator?
    My pool is a 10,500 gallon (420 Sq Ft ) kidney shape. STA-RITE HRPB30, Sand filter 30" 98 GPM, 1 HP Maxi-Glas 2 pump, BBB Method, Taylor K-2005 test kit, 50 Watt 12V low-voltage pond light illuminates the pool at night for a nice soft glow.
    Quote Originally Posted by meatloaf
    Sure! Actually, my Pool Calculator already does most of what you want in a spa/tub calculator. About the only thing I can think of that is missing is bromine calculations. Of course, I am not a hot tub owner, so there could be other things I am forgetting about.
    meatloaf's Avatar
    Feb 2008
    Gilbert AZ
    373
    I have been using the Pool calculator for adjusting my Hot Tub, but I've heard that somethings are different due to the higher temperatures. So far there haven't been any problems.
    There are some differences in how you care for a hot tub, but they don't have to do with the kind of calculations my Pool Calculator does. They have more to do with chlorine being less stable at high temperatures, increased bather load (per gallon) relative to a pool, less exposure to sunlight, and other things like that.
    Guest
    You know what they say about people who give it away for free!
    Seriously, as far as bromine calculations go, I am not sure exactly how that could be done since bromine (hypobromouse acid) is not added directly to the hot tub like chlorine is but is formed in situ by the addition of both bromine and an oxidizer. There are just too many variables. As far as the other calculations go the present calculator should work just fine.
    The main difference for a bromine system is that there would be no CYA and that only total bromine is usually tested so if you had a 'bromine calculator' it would be a bit simplified.
    Perhaps you could have a "bromine mode" that eliminates the CYA and FC/CC/TC inputs and just has a TB (total bromine) input.
    SCCS's Avatar
    Sep 2008
    Left coast
    79
    I would like to see ideal ranges posted on the page. I often do the calculations and need to refer back to my notes for the ideal range. Just a thought.
    16,500 gal Roman end with PebbleFina finish
    4 x 160 intelliflo pump
    Easytouch controls with an IC40 chlorinator
    Sta-rite cartridge filter
    A & A infloor cleaning system
    Pentair 5g LED pool light
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    I'd like to see it tell you how many jugs of liquid chlorine it takes to make the change entered. It already has the percentage and size, I'd just like it to say 3.5 jugs vs. having to do the math.
    Guest
    Quote Originally Posted by JohnT
    Then you would also need to enter the size of the jug and the strength of the chlorine!
    SW Indiana
    9,199
    There's already a place for that.
    Guest
    Yes, but if someone forgets then they might dose wrong. I think a separate conversion calculator addition might be a better idea. Also, how will you do it when you come up with adding 1 19/64 jugs of bleach? (no matter how you cut out ounces are going to be easier unless you have to add whole or half jugs!)
    The mouse over feature already gives you how many quarts, cups, oz. etc you need and is an accurate way to do it instead of fractions of jugs, which are next to impossible to measure and can lead to sloppy pool maintenance techniques, especially for newbies.
    Just my 2 cents.
    Edit: actually the mouse over feature DOES tell you how many jugs you need if you are adding more than a jug of bleach at a time. For example, change the default 4 ppm in the calualtor to 34 ppm (with all other settings on the default--clear your cookies!) with a 96 oz jug and 6% and when you mouse over the amount of chlorine in oz. it will tell you 6.5 96 oz jugs needed (along with the gallons, quarts, pints, cups, ounces, etc!)
    Oct 2007
    Valrico, FL
    542
    Something that migh be of help: Allow user entry of bleach concentration. In my local area there is available 12%, 10%, 6%, 5.25% and 3% and who knows how many others.
    7,500 gal, IG pool, L shape 22' x 15', 1.5 hp pump, cartridge filter, AquaPlus SWG/Controller, Pebble-Tec liner.
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    Quote Originally Posted by dschlic1
    You can already do that, in the FC box at the top, you can change the bleach concentration numbers.
    40 x 16 IG Vinyl. Goldline SWG
    160 Sq Ft Roof mounted solar array
    2014 Hydropool Serenity 5000 Hot Tub
    The Pool School- A great place to start
    Jason's Pool calculator
    SCCS, ideal (recommended/suggested) ranges sound like a great idea. The user will need to fill out a short questionnaire and I will need to find some space to display them in, but that is all possible.
    Jugs and bleach percentage strength are both already available, as others have already pointed out. Jugs are probably only useful when you are shocking at high CYA levels or when you have a huge pool, situations where the number of jugs is high enough that the "rounding to the nearest whole jug" error is low, but it was easy enough to do.
    H2O_Keeper's Avatar
    Nov 2008
    SW Indiana
    140
    A few things.
    1. Add a cost comparison calculator at the bottom. For the math challenged you could just ask for container size and cost. It would do the math for you and let you know your best value.
    2. EDIT: Removed.
    3. I would assume a portion of the audience does not understand the difference between your results if the chemicals they are buying are marketed by weight or volume. Maybe a quick definition of this somewhere, or even better dont display both and only show the results by the most common method of packaging to the general public.
    21K Gal, IG, Vinyl, Bleach-Borax-Baking Soda, 3/4HP Hayward pump, Hayward sand filter, 200,000BTU Heater, TF100 Testkit
    "All that we are arises with our thoughts." - Buddha
    “When fate hands you a lemon, make lemonade.” - Dale Carnegie
    H2O_Keeper's Avatar
    Nov 2008
    SW Indiana
    140
    Whatever container size you pick the results need to come back with that container size FIRST. For example the above for me came back with:
    4 gallons 3 quarts 1 cup 6 oz or 6.5 (96 oz) jugs <--- This only seems to be true for FC
    Data is there but until I read Waterbears reply I had never read over far enough to see the 6.5jugs!!! Perhaps list that first or maybe even only the results that way, take off the 4 gallons, 3 quarts 1 cup 6oz in the results. I doubt most will take it to that much precision dosing their pool. For me its a guesstimate to the container size (ie 1 2/3 jugs needed)
    Great idea, perhaps ONE pull down menu below the pool #Gallons. It would just have ALL 6 combinations, examples:
    SWG-Plaster
    SWG-Vinyl
    SWG-Fiberglass
    NO SWG - Plaster
    NO SWG - Vinyl
    NO SWG - Fiberglass
    You could create a column between the chemical and the NOW column. They must use your "Water Environment" pull down -menu or the calculator responds with no message or an alert to use the pulldown. DEFAULT is NO selection.
    Jan 2009
    Cupertino, CA
    1,966
    Maybe some quantification of the secondary effects of various additives, e.g. when it says "Cal-hypo adds CH" it would be nice to know how much.
    It might clutter the calculator too much to put the conversion right there, but maybe your Chemistry page could say what the ratios are, and the "adds CH" note on the calculator can link to it. Then I can figure out that 4ppm from Cal-hypo also adds 2.8ppm CH, and I won't fret so much.
    --paulr
    BBB "Intermediate Swimmer"
  20. Back To Top    #20
    Quote Originally Posted by PaulR
    You can find that out in the "Effects of adding chemicals" section down at the bottom. It works the other way around, you give it an amount of chemical and it tells you what it does to the water.
