Thread: Jandy Stealth JHPU2.0 sprays when starting.
    morzh's Avatar
    Jul 2015
    Jackson, NJ
    238
    This has been going on since the time the company who built the pool 10 years ago (my first season owning it) had opened the pool (month ago).
    When the pump starts the water sprays out of the rear flange (where the motor is attached). They tightened it but still.
    It does not leak, it is only during the start (very pronounced) and stop (not as pronounced but noticeable).
    I think it is not normal. I am also not sure what would happen if the water did not have any place to go - obviously the burst of pressure is large, wouldn't it blow the pump or pipes? Or is it as simple as changing the gasket and it should hold?
    30,421
    Re: Jandy Stealth JHPU2.0 sprays when starting.
    Probably. It sounds like something is either not fitting correctly or not tight enough. Should be easy enough to have them back out to fix their work.
    Jun 2015
    Wildomar, California
    423
    Your pump needs a new gasket
    morzh's Avatar
    Jul 2015
    Jackson, NJ
    238
    Thanks guys, thought so too.
    Duraleigh,
    No they built it 10 years ago and they won't do it for free, but I can do this myself if it gets bad.
    Mike
