Thread: Safe for me and dog to swim?
    Jul 2015
    Grand Rapids, MI
    13
    Ok been learning and messing with water and testing all week. It's 82 out and would love to go swimming. I tested last night and all my fc was gone again but I also had no cay in there so it wasn't staying so I put my usual 4 cups in plus 3 extra thinking maybe today Fc level would be perfect. I also added instant conditioner to get that up. Well aparently too much bleach was added And the conditioner kept it from evaporating.
    Test results:
    PH 7.4
    FC 11
    TA 230
    CH 240
    CA 35ish right in between 30 and 40.
    No combined clorine
    Or do I need to wait until fc burns off.
    15ft round above ground pool, Vinyl Liner, Used Polygroup Pool Unknown pumps. Single pump skimmer, solar blanket. Just for me and my lab. Will update more as I learn more.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Re: Safe for me and dog to swim?
    Go swimming. Shock level for 30 CYA is 12 FC, and you're below that.
    Jul 2015
    Grand Rapids, MI
    13
    Thank you, diving in after I set the phone down
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Yep,
    It is safe to swim when
    PH is 7.2 to 7.8
    Chlorine is above minimum for your CYA
    Chlorine is below shock for your CYA
    Water is clear
    Chlorine CYA Chart
