Thread: Backwashing Frequency?
    Jul 2012
    Central Texas
    436
    So here's a curiosity question for the collective.....
    What do you use as a backwashing frequency?
    My pool builder advised me to backwash when our filter pressure started to rise and got about the 13-15 psi range (We have a quad 60 DE filter for 12K water). However, I haven't seen it above that pressure in over a year.
    Pool really isn't impacted by trees...more rose bushes than anything and all that stuff gets filtered by skimmer baskets. Mouse picks up any mulch found around the pool that gets in. So essentially, there's never any visible "dirt" in the pool, so no *obvious* reasons to run over and start the process.
    Now...I've gone ahead and backwashed occasionally when I feel like playing, but just wondering if there's some rule ya'all follow?
    Thanks.
    Central TX / 12K GAL / IG / SWG / DE filter / Pentair SVRS & 3 swim jet pumps / Spa bench and jets / Single body of water / No heater.
    michaelrbanks's Avatar
    Sep 2014
    Cibolo, TX
    89
    Re: Backwashing Frequency?
    I don't have a regular frequency. In my pool, the spa has a spillway into the pool - when that starts to trickle instead flow freely, then I backwash. It's approximately 2 1/2 - 3 months and super convenient since I can see it from my back window at the dinner table.
    One thing my builder pointed out was if I opted to use pressure increase as my key indicator, I had to read it with the pump on high. When the pump is low, the pressure gauge never budges.
    16,661 gal IG PebbleTec w/ Spa; 60 ft2 Jandy DE filter, 2 HP Jandy Variable Speed pump; 2 skimmer; 400K BTU Jandy heater; Polaris Sport; opened 9/15/14; TF-100 test kit
    Jul 2012
    Central Texas
    436
    Interesting. I didn't get that caveat relating to the pressure reading. I also do look at the sconces and see their flow. Like your spillway, if that decreases, it is a sure sign of needing to backwash. I Can also see them from the breakfast table and do a visual check every morning at 7:30 or so when the pool starts up.
    I completely took apart the filter and cleaned everything to pristine condition circa October of last year. Since then, I've backwashed twice.
    Inflatableman1's Avatar
    Jun 2015
    Playa Coronado/Panama
    62
    Whenever you decide to do it, I suggest skip the backwash and tear the whole thing down. Clean completely and re-add the correct amount of DE. That filter will then outlast you.
    Now some sand filter guy is going to say "that's why I love my sand filter!!!" No tear down required. Then they will be here in a year talking about broken laterals or some such *****e.
    A bag of DE is 25 lbs. for me. So I will tear down 5 times a year. Takes a half hour. Clean and inspect. There will be no mechanical issues with a schedule like that.
    It's an expensive piece of kit that is worthy of some TLC.
    Ryan
    Ryan
    41' x 16' x 5' IG, 25 000 gallon, cement, tile w/epoxy grout. Overflow/negative edge style. Pentair 4048 DE, Hayward 2 hp Single Speed, Pentair 320 Auto Chlorinator, 1.5 hp Blower f/Jacuzzi, TF-100, city/well (in pool) water option. Located in Panama.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    It is recommended to backwash your filter when pressure rises 20-25% over clean pressure. Here is an article from Pool School about cleaning filters, Pool School - Maintenance and Cleaning of Pool Filters
    Jul 2012
    Central Texas
    436
    Thanks all! I will read that link in pool school.
