Thread: Cant get vacuum to pick up
    I am trying to vacuum pool by hand as cleaner gets stuck. Problem is vacuum doesn't seem to have sucking power. Filters are clean and baskets are empty. Nees help please. Dave
    13000 gallon fiberglass, cartridge filters pentair Intelliflo Variable speed Programmable Pump separate booster pump solar panels on roof
    30,404
    Re: Cant get vacuum to pick up
    What is your psi? What is it normally?
    Do you have good flow from the returns back to the pool?
    I have 23 on top or the filter housing
    I have 23 on top or the filter housing and yes good return
    23 on top of filter tank and yes good return
    Inflatableman1's Avatar
    Jun 2015
    Playa Coronado/Panama
    62
    Start basic. Is the hose or vacuum head plugged?
    Ryan
    41' x 16' x 5' IG, 25 000 gallon, cement, tile w/epoxy grout. Overflow/negative edge style. Pentair 4048 DE, Hayward 2 hp Single Speed, Pentair 320 Auto Chlorinator, 1.5 hp Blower f/Jacuzzi, TF-100, city/well (in pool) water option. Located in Panama.
    I have 23 on top or tank and yes good return
    I worked it back and forth and it had to have been clogged somewhere as it is sucking now THANK YOU EVERYONE!!! now I just gotta look for a cleaner. had a Hayward. MX8 now maybe I'll try a Kreepy krauly. Thanks again
