Thread: Ammonia Problem
    Jul 2015
    st charles IL
    1
    Ammonia Problem
    Hello,
    New to the trouble free pool, but have read many topics on this but was hoping for some individual help!
    First some specifics:
    30,000 gallons
    CYA - 0
    Total Chlorine - 2.7
    Free Chlorine - .2
    pH - 7.7
    After taking my water sample to a local pool store they noted I had very high ammonia and that it would be best to drain and refill a couple of times. So that's done and the results above are after the drain and refills. They called back and said that I needed 45 gallons of chlorine based on their Chlorine Demand test. It went from 75 gallons on initial test, 58 after first drain and refill, now 45 after the second. Seems excessive, but wanted to get some opinions. But a few questions prior to doing this:
    Should I get the pH down?
    Should I get the CYA up?
    Really appreciate any insight - kids are killing me to get it open.
    Brian
    30,431
    Re: Ammonia Problem
    Welcome to the forum. The biggest decision you will have to make is which method to choose....the one we teach or pool store advice. Trying to blend them inevitably leads to failure.....you end up in the middle trying to heed both instructions.
    We would suggest just leave your pH alone....it's close enough.
    Get 30 ppm CYA in your Pool
    Perform the SLAM process.,,,,check it out. It's in Pool School
    robdac's Avatar
    Jun 2014
    Weston, FL
    232
    Re: Ammonia Problem
    First, welcome to the forums!
    To a rookie like me it looks like you need to get the CYA up. Maybe ammonia brought it down but nobody really knows. The pH could come down a little but that's easy. The most important thing, however, is to get one of the recommended test kits so you don't have to rely solely on the pool store's inaccurate tests for sales advice.
    11K gal IG screened-in plaster pool w/ spa
    pentair 150 cartridge filter, Pentair Intelliflow VS pump,
    Aquarite AQR15 SWG, AquaCal Heatwave Heat Pump, TF-100 test kit
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Re: Ammonia Problem
    Ammonia comes from CYA when a certain bacteria breaks it down. You can add CYA now since you've probably added enough bleach to kill the bugger.
    Follow duraleigh. HE THE MAN!!
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Re: Ammonia Problem
    Welcome to TFP!
    Get one of the Recommended Test Kits, I use the TF100 from TFTestkits.net.
    When you get it give us some test results and get ready to SLAM Your Pool.
    Here are some of my fave Pool School articles in case you missed any of them.
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    Here are the Recommended Levels for your pool.
    Here are the Recommended Pool Chemicals and how to add them.
    Use PoolMath to figure out how much to add.
