Thread: Upgrading single speed Super Pump to 2-speed or VS
    Sep 2014
    Ottawa, Ontario, Canada
    18
    Objective: To minimize electricity cost while maintaining a daily turnover of at least 2.0.
    Present situation: My equipment is described in my signature below.
    My intent is to keep the Hayward Super Pump and replace just the 1 HP motor with an appropriate 2-speed or VS motor.
    Using the guidance found in Pool Pump Sizing, I determined the Total Head Loss for my present setup and a corresponding flow rates for Super Pump.
    (a) w/o Solar heating: Total Head Loss 38 ft Flow rate 54 GPM at 3450 RPM; 27 GPM at 1725 RPM
    (b) with Solar heating: Total Head Loss 50 ft Flow rate 39 GPM at 3450 RPM; 19.5 at 1725 RPM
    Assumption: 14 hrs operation w/o Solar, pump at 1725 RPM; 10 hrs operation with Solar, pump at 3450 RPM.
    Upgrade option A: Use existing Super Pump with a 2-speed 1 HP motor
    Using the above numbers I calculated the daily turnover.
    14 h x 27 GPM x 60 min. = 22680 gal and 10 h x 39 GPM x 60 min. = 23400 gal
    24 h total = 46080 gal Daily turnover = 46080 : 21000 = 2.2
    I'd be grateful for comments, suggestions of other options and motor suppliers.
    21K gal, IG plaster new 2010, 3/4 HP Super Pump with 2-speed AO Smith motor w/integrated 2Green timer, sand filter S-244T2, solar heating with HM-4000D controller, Dolphin M400 pool cleaner.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Upgrading single speed Super Pump to 2-speed or VS
    Turnover per day is relatively meaningless.
    Pool School - Determine Pump Run Time
    Isolated Spa - 345 Gallons
