Results 1 to 9 of 9
Thread: Can algae be spread by a garden hose?
    Jul 2015
    MIDLAND, TX
    44
    I hope this doesn't sound like a silly question but I'm new at all of this. We drained our algae infested pool and will soon set up a new pool. Will it be a problem to use the same hose to fill as we did to drain? I don't want to spread anything to our pretty new pool.
    5700 gal easy set AGP , 2500 gph intex pump, TF-100.
    Sep 2013
    Connecticut
    728
    Re: Can algae be spread by a garden hose?
    I would certainly flush out the hose for a couple minutes before putting it in the new pool. There's not much point in getting more hard core than that, since your pool will not be in a sterile environment, and new algae spores will have free access. Maintain good chlorine levels to keep them from flourishing and multiplying.
    18' x 48" ring top pool (Summer Escapes); 5500 gallons; set up June - October, stored during winter; Intex 2500 gph pump (B size cartridge filter) Hayward 21" sand filter + 1.5 hp single speed Powerflo Matrix pump (upgrade October 2016) *** K-2006 test kit, refills from tftestkits
    Jul 2015
    MIDLAND, TX
    44
    Ok thanks. I've actually been having dreams about algae so I want to do it right this time lol. I see we will have the same set up as you in a couple of weeks. May I ask what a Unicel cartidge is?
    Sep 2013
    Connecticut
    728
    Unicel C-5315 (can find on Amazon and elsewhere) is a better quality, made in USA incidentally, filter cartridge. It is size compatible with the Intex B. As others had suggested, I find the Unicel cartridge does a better job, and also seems easier to clean. Dirt seems to come off more easily when I spray the filter with a garden hose. I always washed and reused the generic B cartridges also - seemed wasteful and unnecessary to throw them away after one use.
    Edited to add: If you do decide to buy a Unicel cartridge at some point, double and triple check that you're getting a genuine brand name item. I remember reading lots of complaints from people who ended up with "Unicel compatible" cartridges - i.e. the same lower quality stuff they were aiming to replace.
    Jul 2015
    MIDLAND, TX
    44
    Thanks! We were using A cartridges with our first pool and we reused them, too. Since we don't have our new pump or the filters yet we may look into Unicels. If they work well, it may be worth the price difference!
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Dont worry about the water hose.
    Algae spores are everywhere. They float around in the air and land in pool water everywhere evey single day. There is no escaping it.
    The trick is to know how to manage the pool to keep it away.
    I commented in your other thread, so I wont comment more on water care in this one.
    Theres no need to feel overwhelmed or have nightmares. We are here to help you.
    take a deep breath, exhale, and relax. You are in good hands here.
    Divin Dave,
    Jul 2015
    MIDLAND, TX
    44
    I'm starting to feel more excited than overwhelmed. So glad I found y'all!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    Get any thick green sludge out of the hose.
    Normal chlorine levels will kill anything the hose brings in otherwise. You'll probably want to start with a higher than normal FC anyway, since there's probably some residual algae spores lurking, and that will help. Toss any pool toys in to soak in the highly chlorinated water, too. And if I had a pool noodle that had been in a green sludge pond, I think I'd toss it and buy a new one. Too many hiding places on those things.
    Jul 2015
    MIDLAND, TX
    44
    I never thought about the pool toys! Only the pool, ladder, and hose. Thanks!!
