Thread: Is there anything I need to be doing immediately after having people in the pool?
    Jul 2015
    AZ
    19
    So I've finally got my pool back to looking crystal clear thanks to this site. I want to keep it that way so I was wondering if I need to be doing anything after having people in the pool. Should I wait a while and test the chlorine afterwards? Should I turn on the pump?
    16000 Gallons, Plaster, Sand Filter, Hayward Superpump II.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Is there anything I need to be doing immediately after having people in the pool?
    The usual recommendation and what I do is to raise your FC above what you normally would BEFORE having a large number of people in the pool. If it's just a couple people, no need to go over your normal target numbers.
    For instance, I have a minimum FC of 3 ppm. I normally dose daily or every other day, depending on usage, up to 5-6 ppm. Before a large party or similar, I might bring my FC up to 8 or 10 depending on the guests. After the guests leave, it's a good idea to check to see if the FC is still above your minimum and bring it back up if needed.
    Isolated Spa - 345 Gallons
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    You should turn the pump on for 30 mins-1hr then test. Add bleach if needed. Remember vacuuming and brushing are also key to keeping the pool crystal clear.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,672
    I turn on the pump and test FC as soon as I can.
    I also raise my FC up to SLAM level for the night just because it makes me happy to know I "killed" anything they might have added to the pool.
    Kim
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    A couple people, nothing special. A pool party, raise FC a couple points before and after and leave the filter run a while until clarity is restored.
    Mar 2007
    San Rafael, CA USA
    12,082
    Every person-hour in a 16,000 gallon pool consumes around 0.066 ppm FC so a few people is no big deal. If you've got 10 people in the pool for 3 hours, now you've got 2 ppm FC of extra chlorine demand. If someone urinates, each cup of urine is equivalent to around 5 person-hours so around 0.3 ppm FC of chlorine needed to get rid of it.
