Thread: 1985 pool
    May 2015
    Moline, IL
    31
    1985 pool
    I have a sparton pool and I know sparton is no longer in business. My pool was put in before 1985 and needs repaired. Would it be better to redo the whole pool or to replace the top metal that holds the pool liner. I have two skimmers and the one away from the pump dosent suck as much as the one closest to the pump. In fact the one furthest away hardly sucks. And I only have three jets. One on the built in stairs, one on the shallow end and one at the deep end. And the are at the top of the water. Maybe pool builders do things diff now than they did back in 1985. Any help would be Appreciated.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,411
    Re: 1985 pool
    What part of your pool needs repair? A picture is worth 1000 words..............
    Do you have valves that control your skimmers and returns?
    Kim
    May 2015
    Moline, IL
    31
    Re: 1985 pool
    pool coping
