Thread: How does PhosFree and other phosphate removers work?
    May 2011
    PA
    38
    Interested in the actual chemistry, especially because at least PhosFree claims it "is formulated from lanthanum compounds."
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: How does PhosFree and other phosphate removers work?
    Lanthanum chloride reacts with the free, dissolved phosphate compounds to form a salt (precipitate) of Lanthanum and phosphate (lanthanum phosphate) which is not soluble in water. The chlorine ion from the Lanthanum chloride likely ends up bound to free sodium ions to form sodium chloride, table salt, which would dissolve in water. Lanthanum sulfate is also in these phosphate removers and reacts in a similar way with phosphate.
    Lathanum itself is classified as a rare earth element. It's not actually that rare in deposits, it's just fairly difficult to mine and extract, hence why phosphate removers with lanthanum compounds are relatively expensive and largely unnecessary if proper chlorine levels are maintained.
    chem geek may have more enlightened details on this but that's the Reader's Digest, probably somewhat correct explanation.
    Isolated Spa - 345 Gallons
    Mar 2007
    San Rafael, CA USA
    12,082
    That's a good explanation and the only thing to add is that when you add a phosphate remover to the water it will generally cloud it temporarily until the precipitate is caught in the filter. The fact that it clouds does not necessarily mean you have phosphates in the water. Lanthanum also precipitates with carbonate and mostly what you see is lanthanum carbonate that gets caught in the filter. If there are phosphates, then they are less soluble than carbonate so with lanthanum carbonate in the filter the carbonate gets exchanges with phosphate if there is any left in the pool. So this means that you don't want to backwash your filter too soon after a treatment. Probably waiting one week is plenty (it might only take a day or two, but I don't know for sure).
    Some products such as PhosFREE also contain clarifiers in them to help remove the cloudiness more quickly. Other products, such as Orenda PR10,000 don't have clarifiers so the pool may remain cloudy for a while (days) if you don't use a clarifier. You can read about my experience with this in the thread Orenda Technologies PR-1000 and CV-700 Products.
    Apr 2009
    Burlington, ON, Canada
    344
    I used PhosFree several years ago (before I stopped worry about phosphates and just enjoyed my pool - I had no problems at the time, but believed the pool store that the phosphates were too high). I poured it into my skimmer very, very slowly and there was no clouding of my water at all. If you pour it in too fast, it will cloud your water.
    16x28 Roman, 55000 litres, salt water, Zodiac Duoclear 130 (mineral cartridge removed!!!), inground, vinyl liner
    Hayward Tri-star VS900 (1.85 HP) pump, Hayward C3030 cartridge filter
    Nine Techno Solis 4x10 solar panels, Jandy LX 250 natural gas heater
    Jandy Aqualink PDA with Sub Panel Power Centre
