Page 1 of 2 12 LastLast
Results 1 to 20 of 39
Thread: New and TERRIFIED pool owner
    Jul 2015
    MIDLAND, TX
    44
    Hey, Y'all. We will be getting our second pool in a little over a week. Our first one was a 15' x 36" ABG and ended in an algae apocalypse after a month. I admit that we had ZERO knowledge of pool chemistry so it was totally our fault. Now we're going to give it one more shot so our fair skinned family can beat the West Texas heat and still spend time outdoors. I'm terrified of a repeat with the algae. I've been reading various things on this site and feel completely overwhelmed. It all seems very complicated. I came here so that, HOPEFULLY, we can start off right from the get-go.
    5700 gal easy set AGP , 2500 gph intex pump, TF-100.
    Apr 2015
    Quinlan, tx
    811
    Re: New and TERRIFIED pool owner
    Welcome! You've come to the right place! To properly balance your pool, you'll want to be sure you order a recommended test kit so you can get your water right from the beginning.
    Lisa P.
    26,000 IG, pebble tec, flagstone, pentair Triton II TR100 sand filter & VS+SVRS 3hp multi-speed pump, Intellichlor IC-40 SWG, Pentair Booster Cleaner, spillover spa, waterfall, Taylor K-2006 testkit
    [It is better to know how to learn, than to know. - Dr. Seuss[/I]
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Welcome to TFP!
    This guide will guide you through the process.
    Pool School - Guide for Seasonal/Temporary Pools
    Jul 2015
    MIDLAND, TX
    44
    Thank you! I was just reading about those. Any suggestions on which one we should get?
    Apr 2015
    Quinlan, tx
    811
    According to the article on seasonal pools, you could get by with a simple two way OTO test that you can pick up at Walmart.
    Lisa P.
    Jul 2015
    MIDLAND, TX
    44
    I read that but I noticed it said that if it's more than 3000 gal, you should go to the larger pool instructions?
    Apr 2015
    Quinlan, tx
    811
    Then I would splurge and get the TF100. It has better amounts of the reagents you will use most often.
    Lisa P.
    Apr 2015
    Quinlan, tx
    811
    It's worth the money and you'll
    Have full control of your pool.
    Lisa P.
    DFW, TX
    24,502
    Yes, you can definitely go full meal deal and get the TF100, it's my favorite test kit.
    Here are some of my fave Pool School articles to get your started.
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    Here are the Recommended Levels for your pool.
    Here are the Recommended Pool Chemicals and how to add them.
    Use PoolMath to figure out how much to add.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,559
    We are here to help you have a clear pool!
    You are already on the right direction---------finding TFP and posting!
    Now you need to get a good test kit. Go ahead and get the TF-100 as you WILL end up ordering more of the regents and will end up spending MORE in the end if you get the Taylor K2006.
    Look at my siggy to see the two test kits compared and where to buy them.
    Once you get your test kit let us know and we can walk you through how to do the tests.
    While you are waiting for your kit and pool start looking around your area for your best place to buy bleach. Walmart has Greater Value bleach that is 8%, pool stores have chlorine (same as bleach but stronger) that is 11%.
    We are here for you!
    Kim
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    Hi,
    There is no reason to feel overwhelmed. We are here to help you out.
    Its really simple. Teh most important thing, is to have a good test kit. The TF100 is the ticket. You wont regret it.
    After that, if you will just test the water regularly and adjust the parameters to the recommended levels which that nut pooldv provided a link to, then you will be off and running. And that handy tool called pool math will be your best friend. It will tell you what and how much of something to put in the water.
    Thats really all there is to it... in a month or less when you start getting the hang of it, you will start to wonder why you ever felt overwhelmed in the frist place.
    So, take a deep breath, and exhale. You are in good hands here.
    Quote Originally Posted by kmatheson View Post
    Divin Dave,
    Apr 2015
    Quinlan, tx
    811
    Quote Originally Posted by Divin Dave View Post
    Hi,
    So, take a deep breath, and exhale. You are in good hands.
    THIS is very true! Dave sent me a similar "it's ok to be overwhelmed reply" a few months ago. He's exactly right!
    Lisa P.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    Quote Originally Posted by Pogueld View Post
    Lisa P.
    Divin Dave,
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Get a proper test kit and you won't be working blind and you can tame the pool no problem.
    And once you're in control, your wallet will stop bleeding cash and your pool will be the envy of all you swim in it. Your children will become pool snobs and refuse to dip a toe into anyone else's water. Life will be good.
    Jul 2015
    MIDLAND, TX
    44
    Thanks everyone! I'll let you know when we get the test kit!
    Jul 2015
    MIDLAND, TX
    44
    How important is the speed stirrer? Is it something we can live without for a bit? Hubby got laid off today so I only want necessities. Also, we have all of these chemicals-HTH brand. I've been reading a lot about the BBB method. My questions are, can we use what we have and then change to the BBB method or are we stuck once we put this stuff in the pool? We have spent soooo much money. I'd really love to be able to stop doing that.
    Richard320's Avatar
    Jan 2010
    19,037
    The speed stirrer is not mandatory. Once you have one, you will think so, but ignorance is bliss. You can wait and get it for Christmas or Father's Day or something.
    What HTH chemicals do you have? The pH up is just soda ash, pH down is dry acid, Alkalinity Increaser is baking soda, and CYA is CYA. The HTH CYA actually gets good reviews here; fast dissolving. If you have Calcium Hardness Increaser, you won't need it with your vinyl pool. Save it to melt ice next winter.
    Depending on test results, any Cal-hypo you have might be useful to chlorinate with until a) its gone or b) CH levels are too high.
    If you run short of CYA and have dichlor or trichlor, they can be used to chlorinate and raise CYA, but they are acidic, so be careful with them.
    If you post a list of what you have with your test results, somebody will be along to guide you. We're all about saving money. If you already own the stuff, use it. Just don't buy the overpriced stuff again in the future.
    Jul 2015
    MIDLAND, TX
    44
    I'm very excited about this not costing a fortune! Is CYA the stabilzer? If so, I have that. I also have the ph up and ph down, shock and swim, super algae guard (just bought that a few days ago and haven't used it obviously lol), 3" and 1" chlorine tabs...that might be it. I'm thinking that's it. If there is more I'll post when I get my test kit.
    DFW, TX
    24,502
    Yes, CYA is stabilizer.
    Here is a list of pool chemicals, what they do and how to add them.
  20. Back To Top    #20
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    Actually, TFP is about adding to your water ONLY what the water needs.
    You will need stabilizer for sure.
    we dont recommend using the chlorine tabs as a steady source of chlorine, only liquid chlorine (a.k.a. bleach). Bleach is less expnsive than tabs, and those tabs also can add things in the water that is NOT needed.
    You will not need any of the algaeguard either.
    Dont go out and buy anything else. Like you say, we wont know what else you might need until the water gets tested.
    Divin Dave,
