Results 1 to 12 of 12
Thread: Where to buy Dichlor
    Jul 2013
    East Meadow, NY
    10
    I can't for the life of me find on here what dichlor I should purchase. I recall that it shouldn't have calcium in it?? Does this still hold true? Is there a store I can purchase it from? I had purchased a bag from Amazon but I'd like to get the pool set up this weekend but am completely out of dichlor.
    Wanda
    Intex 10x30 pop up pool, 1,018 gallons, Krystal clear model 603 filter pump, not installed yet.
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    Re: Where to buy Dichlor
    time for pool school.
    dichlor doesn't have calcium, it has stabilizer (CYA). cal-po (sp?) has calcium. neither are recommended here.
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    Sep 2013
    Connecticut
    728
    Just look in the pool section of the nearest big box store, and read ingredients on the various one-pound bags of 'shock' - you're looking for sodium dichloro-s-triazinetrione, without any other major active ingredients.
    I'm reading from a bag I picked up at Ocean State Job Lot a month ago - not sure if that chain reaches into NY.
    18' x 48" ring top pool (Summer Escapes); 5500 gallons; set up June - October, stored during winter; Intex 2500 gph pump (B size cartridge filter) Hayward 21" sand filter + 1.5 hp single speed Powerflo Matrix pump (upgrade October 2016) *** K-2006 test kit, refills from tftestkits
    Sep 2013
    Connecticut
    728
    Dichlor is fine during startup, you just don't want to keep using it once your stabilizer (CYA) levels are high enough. Personally, I add stabilizer separately and use liquid chlorine right from the beginning after setting up our pool each year; but dichlor can be part of startup - I think I remember reading about that approach at the PoolForum website.
    Please read this also
    Pool School - Guide for Seasonal/Temporary Pools
    Jul 2013
    East Meadow, NY
    10
    I have used the dichlor for the first 4 days then switched over to bleach. It's worked very well for me thus far. I just wasn't sure if I can locate the actual dichlor in a store. I thought I read somewhere some dichlors have calcium in them but could be confusing it with something else. Either way thank you. I will do a search for my local stores and hope they carry it.
    Wanda
    Sep 2013
    Connecticut
    728
    There are two common forms of powdered shock - dichlor (which has stabilizer along with chlorine) and cal-hypo (which adds calcium along with chlorine). Just get the one that has a label like the one I quoted earlier - no mention of calcium, and no other 'super duper enhanced' multi-function ingredients ��
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    You can find dichlor in the pool sections of most big box stores such as Home Depot, Walmart or farm/garden/hardware stores. Be sure to just get dichlor or "Dichloroisocyanuric acid" on the label. Do not use products that have any copper compounds listed on the packaging.
    Isolated Spa - 345 Gallons
    Jan 2013
    Long Island, NY
    184
    Depot, Lowes, Leslie's, Walmart (maybe)...
    Doughboy 12' x 20' Saphire semi-AG, Installed 2012
    Waterway 1.5 HP 2 speed, 100 sqft cartridge filter
    Aprox 7000 Gal, Full sun, 85K heat pump,
    TF-100 test kit
    Thimble's Avatar
    Apr 2013
    Wichita, KS
    93
    The Walmart I was at the other day had nothing but trichlor...but they had 2-3 fancy versions of it.
    15x30 IGP; 20,000 gallons; plaster
    Hayward SP2607X10 Pump; Purex Triton Tagelus Sand Filter
    Hayward Goldline T-Cell 15 SWG; Aquarite G1 Control
    Southwest Spas 400 gallon hot tub w/ozone
    TF 100 with speed stir
    Mar 2007
    San Rafael, CA USA
    12,082
    Usually, but not always, Dichlor is called "chlorinating granules" or "stabilized chlorinating granules" or "granular chlorine". Definitely check the ingredients for "Sodium Dichloro-s-Triazinetrione" or "Sodium dichloroisocyanurate dihydrate" or something similar with "dichlor" in it and it normally is around 99% concentration and may also separately say 56% Available Chlorine.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by DaninFLA View Post
    Not always as a sole source for long term use, but there are plenty of circumstances where these are of value.
    Essential Links:
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    It appears from looking at google maps that there are three Leslies close to you. You can buy Dichlor as "Chlor Brite" in one pound packets. One of them will take your CYA to 40, but don't dump it all in at once. You'll bleach the vinyl if you do.
