Thread: Wes45 is checking in
    Feb 2009
    Garland, TX
    74
    I was looking around the net for cheap chemicals to start up the pool in a couple of months here in the DFW area and found this website. I've learned quite a lot in the last hour reading the info here and will probably go the BBB route over the summer after the current chemicals are depleted. Looking forward to learning a lot from the folks here.
    This is my first pool and I had it built 3 1/2 years ago.
    18,000 Gallon IG, Gunite, Cartridge filters
    Rainbow 320 Chlorine feeder (not in use anymore), 2.0HP Pentair WhisperFlo
    Legend Platinum Hummer Pool Cleaner
    No P in my ool's Avatar
    Jun 2007
    Logan IA
    219
    Re: Wes45 is checking in
    Howdy,Wes. The information on this sight will have you spending less time and money on our pool and spending more time in it
    21' Leslies Beachland Ag Pool, 10,000 gallons, professionally installed (best money I ever spent) Hayward 16" sand filter w/Pentair two speed pump Fafco 4x20 solar heater,Aqua Trol RJ. Borates added. Hard plumbed.
    Butterfly's Avatar
    South Carolina
    10,045
    Hi Wes45 and welcome to TFP!
    You've found the best pool site on the net, IMHO!
    We've got plenty of room for another pool owner from Texas!
    As I keep wondering, "Does everyone in Texas have a pool?!"
    You're done SLAMing when:
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,965
    Welcome! You won't regret switching to BBB.
    http://www.PerfectlyClearPoolService.com
    rogerbrks's Avatar
    Round Rock, TX
    172
    Welcome Wes45. We can never have too many Texans. post pictures of your backyard oasis!!!!
    21,200 gal IG gunite, CL 580 sqft Cartridge filter, aqua pure salt system, polaris 480-blue&white, Jandy PDA Remote, (4) Jandy Deck Jets
    Welcome to TFP! You have managed to stumble upon the cheapest chemicals available!
    8200 gallon 20' x 48" round vinyl frame pool, manually chlorinated with 10% liquid, salt added to ~2000, 12" sand filter, 1600gph pump, TF100 test kit
