Thread: Using WAter softener in pool plaster
    Today, our Gunnite pool was replastered. I forgot to bypass the water softener. Thus, they used soft water to mix the plaster. The pool will be filled with "regular" unsoftened water.
    If pool water is balanced, could the use of softened water in the plaster cause a problem?
    Thanks
    30,000 gallons, DE Hayeward Filter, Plaster, In-ground
    WE keep the Chlorinator filled with tabs
    Jul 2011
    Arizona & California
    803
    Re: Using WAter softener in pool plaster
    No, it won't cause any problems or make any difference at all to the plaster mix.
