Thread: Day 2 of conversion
    Jun 2007
    Michigan
    16
    Day 2 of conversion
    I can see the Baquajunk free light at the end of the tunnel now.
    I have been pouring ultra bleach in every 3 hours today. The water turned a lighter shade of green in about 15 min. and has been getting lighter all day, still cloudy and cant see the bottom of the pool yet but its getting better.
    Most of the day there has been green particles floating on top of the water, been skimming them up and backwashing often.
    I have been reading all the posts here and at the poolforum and couldnt of done this without all the great advice from you all
    Thanks
    14 x 22 10k gal AG chois pool, sand filter,.....still working on the tester
    10k AG Chois Pool
    Sand Filter
    Royal Entrance Stairs
    Arizona
    924
    Sounds like progress!
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    mbar's Avatar
    Ashland PA
    257
    Great job The more consistant you are with bleach, the faster the conversion - and you are a prime example
    16x33 fiberglass pool sand filter
    Jun 2007
    Michigan
    16
    Going into day 3 I lost 5 ppm overnight so i added another 1.5 gal of bleach to bring it back up to 15 ppm.
    Still a little unclear as to the delivery method of the bleach as some posters say they add it to the skimmer.
    Is walking around the pool and dumping it in not as good to do?
    thanks
    tld
    10k AG Chois Pool
    Sand Filter
    Walking around is fine, as is pouring slowly in front of the return, or pouring slowly into the skimmer. Some do not like to add chems to the skimmer because the pump/filter directions say it can cause damage. If your pump is running and you pour slowly, the chems will be pretty dilute by the time it gets to any equipment.
    Welcome to TFP!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    Jun 2007
    Michigan
    16
    thanks for clearing that up
    10k AG Chois Pool
    Sand Filter
