Thread: Do I have Algae?
    Jul 2014
    NJ
    46
    Do I have Algae?
    I have what either is dirt or algae on some of the floor of my pool. If you brush it or vacuum it, it dissipates. All my numbers are perfect, I have never let the chlorine go below what it should for my CYA (I even aim a little higher). My thermometer rope had a greenish hint to the top part (I had it hanging from the outside of my pool so I think that is why b/c the chlorine is not getting to that part). I have gotten a new rope, and I am fine with that. Otherwise my pool is crystal clear, and no other problems. Do I need to slam? I would think not, because everything is perfect, but I wanted to get your guys expert opinion on it.
    5,700 gallon, Carribean Isle 15x52 Round Above Pool.
    Cartridge Filter.
    Installed Fall, 2014.
    North New Jersey
    Using the TF100 test
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Do I have Algae?
    Most likely dirt but if you post actual test results, you'll get more reassurance.
    Isolated Spa - 345 Gallons
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    could be algae, could be pollen, best way to find out is do the OCLT. raise your FC up near the SLAM and do the test. don't need to go to full SLAM level, but get it elevated
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
