Thread: Hayward DE Pool Filter Pressure
    Jul 2015
    Tucson
    1
    Hi all,
    I recently have been trying to get my pool working after years of stagnation. I purchased a new Hayward 48sqft DE filter and installed it myself. When i flip the system on, i can immediately see the pressure rise to over 30lbs. This happened within 1 minute of turning the system on for the first time too. I also tried cleaning the grids, but the pressure continues to be the same. Any advice would be greatly appreciated!
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Hayward DE Pool Filter Pressure
    We'll need more information about your pool set up, especially your pump. What filter did your remove in order to install this one?
    Update your forum signature with as many details as possible, see mine for reference. Go to the Settings link on the upper right of the page, then Edit Signature on the left of the next page.
    Isolated Spa - 345 Gallons
    Inflatableman1's Avatar
    Jun 2015
    Playa Coronado/Panama
    62
    Is it circulating well to the pool?
    Ryan
    41' x 16' x 5' IG, 25 000 gallon, cement, tile w/epoxy grout. Overflow/negative edge style. Pentair 4048 DE, Hayward 2 hp Single Speed, Pentair 320 Auto Chlorinator, 1.5 hp Blower f/Jacuzzi, TF-100, city/well (in pool) water option. Located in Panama.
    Jun 2015
    Wildomar, California
    423
    Hi Jon. It really sounds like you installed the filter wrong. I don't mean to insult you. I just want to help. Perhaps you can double check your install instructions? You have 3 ports to plumb in and I once plumbed one in backwards and it did what yours is doing now
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    426
    Did you install a push pull or multiport valve. I agree, there may be a problem with plumbing connections. Check to make sure they are going to right place. Also with a 48, you need 6lbs of DE when you charge a clean filter.
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    poolside@haywardnet.com
