Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Thread: 18v circuit breaker keeps tripping on Pentair
    Aug 2014
    TX
    39
    I hooked up a skimmer vacuum to vacuum out our hot tub and all was well but after I turned it off now the 18v circuit breaker labeled relays keeps tripping and pumps won't turn off. Can someone tell me what relays it control so I can start disconnecting to isolate the issue? Thank you.
    Pentair i7+3
    Apr 2013
    Sacramento, CA
    2,769
    Re: 18v circuit breaker keeps tripping on Pentair
    Ok I confess I'm no spa expert but I am lost. What brand and model skimmer vacuum did you hook up?
    Where and how did you hook it up?
    Is there a schematic on the spa? What brand and model of spa?
    if you disconnect it does it go back to normal?
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    Probably just a coincidence that this happened right after you vacuumed. At the panel, that is at the equipment there are two screws top left and right. Unscrewing those will allow you to open and expose the board. Relay sockets will be on the top of the board labeled FLTR PUMP, Aux 1, aux2, and so on. Start with the filter pump (pump that is running?) and unplug the relay from its socket and then try to reset the small breaker. If it holds, then the problem is either with the relay, or the socket (circuit board). My guess would be the relay.
    Note: You may try tapping the associated relay before you start this procedure. If tapping the relay shuts the pump off and you are able to set the breaker, change out the relay.
    Factory Warranty Station for:
    Aug 2014
    TX
    39
    Will try that now thanks!
    32,000 Plaster Pool
    SWG Hayword Swimpure, chlorine feeder, Triton II 140c sand filter, Filter motor - 2HP VSP
    Decent - 1/2HP motor
    Cannon Jets under diving board - 2HP
    Cleaner Polaris 280 - 3/4HP motor
    Aug 2014
    TX
    39
    Ok so I unplugged each relay from the board and it still does it it only happens when I turn on the gfi/lights breaker and seems it has something to do with gfi circuit. I tested the gfi plug next to box (it wasn't tripped) and now it won't reset. Maybe spa light or that plug is bad? Kinda odd plug just went bad.
    32,000 Plaster Pool
    Aug 2014
    TX
    39
    Is the spa side remote in the GFI loop?
    32,000 Plaster Pool
    Aug 2014
    TX
    39
    So just to make sure in doing this correctly... I'm supposed to remove all the wires from the output from each relay one at a time then see if the 3amp breaker trips when power is turned on?
    32,000 Plaster Pool
    Aug 2014
    TX
    39
    Please help me I am dying
    32,000 Plaster Pool
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    If the GFI plug will not reset then it needs to be replaced. They fail over time, that is normal.
    Aug 2014
    TX
    39
    Well not sure if it just won't reset due to power not being on long enough. Requires power to reset I thought. Plus it didn't trip normally, I did test after after I had the issue.
    32,000 Plaster Pool
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    Quote Originally Posted by drpepper68 View Post
    Don't remove any wires from the relay (that would require a screwdriver), instead, unplug the relay from the board (2 Thin wires with a small plug on the end that plugs into the board).
    Aug 2014
    TX
    39
    Oh I did that to each one and no go. I was trying to remove the wires from the relay to the pool equip but that hasn't worked either.
    32,000 Plaster Pool
    Aug 2014
    TX
    39
    Plus i didn't think the gfci receptacle would cause the 3amp breaker to trip regardless.
    I unhooked the wires to the pool lights also in case there was water in them.
    32,000 Plaster Pool
    Aug 2014
    TX
    39
    The only pwr breaker I have to turn on for it to trip is labeled "pool and spa lights and GFCI"
    32,000 Plaster Pool
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    If you had the relays UNPLUGGED from the board and you couldn't reset the small breaker, it is either the board or the small breaker. If you can manage to disconnect the load side from the small breaker, and the breaker holds, something is shorted on the board. If it wont reset, it is the small breaker.
    Aug 2014
    TX
    39
    Thanks. I'll try that disconnecting the load side of the 3am breaker. I'm going to replace the gfci receptacle for kicks.
    No way it could be transformer huh?
    32,000 Plaster Pool
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    You can if you want, unrelated though.
    Sure it could, check voltage on the line side of the breaker while powered up. Should be 28-32V
    Aug 2014
    TX
    39
    Yeah it's 28v when disconnected and powered up. When I disconnect from control board it doesn't blow. Replaced GFI receptacle just for kicks.
    I'm thinking to try replacing the 3amp breaker and/or transformer cause I don't want to spend $750 on a control board!
    32,000 Plaster Pool
    Aug 2014
    TX
    39
    Anyone know the transformer manufacturer? I can't imagine a transformer cost that much without the pentair name on it.
    32,000 Plaster Pool
  20. Back To Top    #20
    Aug 2014
    TX
    39
    Switched 3amp breakers and no go. I used to do electronics so maybe I can fix the board itself. Hard to below the board is shorting with nothing connected.
    32,000 Plaster Pool
