Results 1 to 20 of 20
Thread: DIY Magnetic Stirrer
    Backglass's Avatar
    Jun 2007
    Putnam County, NY
    139
    I certainly don't want to rain on anyones parade as those look very slick and well designed.
    That being said, stir plates are very easy to make for under $15 if you are a handy DIY'r. I am a homebrewer and we use stir plates for yeast propagation. Homebrewers are notoriously cheap and many make there own stir plates out of an old computers muffin fan, rheostat and a couple of rare earth magnets. They are designed to run on 110 volts and spin/support MUCH larger flasks (4,5,6 liters!) but you could easily scale it down and make a mini DC unit. Half the electronics homebrewers need are to convert AC to DC, which would be unnecessary for pool testing as the fans are DC anyway. The magnetic stir bars are available everywhere...even eBay.
    Ideas and Inspiration:
    Stirplate Wiki How-To
    Tupperware Stir Plate
    Cigar Box Stir Plate
    Another Stirplate How-to
    Guest
    To make a DIY magnetic stirrer with an electronic speed control and in a plastic case will cost more in the realm of $35 to $40 dollars. I know because I priced them out. You can make a very basic one with just a rheostat and a PC fan motor and a power supply for about $15 if you put it in something like a margarine tub or something like that. Not everyone is a DIYer and for those that arent' the Apollo Pools unit IS an excellent value!!
    nikonsal's Avatar
    Royal Palm Beach, Fl
    17
    I did make an AC version with a old pc fan but it just wasn't very convenient. When I looked into making a decent DC version it was going to run around $37. Went on ebay just to see what was available and most DC powered stirrers were over $75 used and not in very good condition. Then I came across this one without the beaker and rod (I use the taylor comparator tube and a small magnetic rod from my son's magnetix set )for $35. Shipped the total was $42. Worth every penny!!!
    18 x 36 21k gal. IG / DiamondBrite / Aquarite SWCG/ 1hp Pentair WhisperFlo pump/Pentair C&C 150 cart. filter
    Backglass's Avatar
    Jun 2007
    Putnam County, NY
    139
    Quote Originally Posted by nikonsal
    What one is $35? The OP's link shows $79 dollars. ($65 +14 shipping.)
    Another option is Ebay.
    Magnetic stirrers are all fairly much the same, and there is a wide selection on Ebay for fairly cheap.
    The DC battery powered bit offered by the original post is a nice feature though if you need it, but most people lately seem to be testing at their kitchen tables not by the pool.
    Jim
    nikonsal's Avatar
    17
    Quote Originally Posted by Backglass
    The unit that I purchased for $35 on ebay is the older style unit that Paul use to make and did not come with beaker and stir bar. The new version is somewhat smaller.
    AV8TOR's Avatar
    Dec 2008
    Fort Worth TX
    211
    Split off of Portable Magnetic Stirrer from Apollo Pools. Jason Lion
    What did you use for a magnet? I made one that works flawlessly from a PC fan and used the rare earth magnet from an old hard drive just as internet plans indicate and with a 12v power source work for all 25ml volumes without any need to adjust speed and I use a 9v power source for the 10 ml volumes again not needing any speed adjustment. my local Leslies gave me the stirrer bar (yes gave as in free) so I had no cost in putting mine together.
    16,000 gal IG Double Roman Plaster Pool (16yrs - plaster redone 2014)
    Pentair FNS-48 DE filter with WhisperFlo 2HP single speed pump
    Polaris 280 robot
    BBB all the way and tested with a TF100 kit
    Pool Calc user
    meatloaf's Avatar
    Feb 2008
    Gilbert AZ
    373
    Re: Portable Magnetic Stirrer from Apollo Pools
    I made one yesterday from some spare parts that were laying around. Works great! I used a brad as a stir stick, a CD cover for a tray, on old 12V power supply and the magnet is from an old hard drive. Cost $0.00
    My pool is a 10,500 gallon (420 Sq Ft ) kidney shape. STA-RITE HRPB30, Sand filter 30" 98 GPM, 1 HP Maxi-Glas 2 pump, BBB Method, Taylor K-2005 test kit, 50 Watt 12V low-voltage pond light illuminates the pool at night for a nice soft glow.
    AV8TOR's Avatar
    Dec 2008
    Fort Worth TX
    211
    Well done meatloaf - good idea on the CD case. I used a small piece of acrylic for mine. How did you attach your magnet and what about balance. I used velcro so I could reposition the magnet to get a good balance. Glad you posted a picture in operation so those can see the results.
    Polaris 280 robot
    Pool Calc user
    Guest
    Quote Originally Posted by meatloaf
    invest the $3 and get a non-reactive teflon coated stirbar. Using brad can cause interference with some of the tests since it is possible that some of the reagents could react with the metal (and we are dealing with redox reactions in the FAS-DPD test and the CH test can suffer interference from metals).
    meatloaf's Avatar
    Feb 2008
    Gilbert AZ
    373
    Re: DIY Magnetic Stirrer
    The magnet is attached with double stick tape. It took a little trial and error to get it positioned properly. Where can I get a non-reactive teflon coated stirbar?
    Guest
    EBay or a laboratory equipment dealer such as Cole Parmer. Just search for stir bar or spin bar and you will find many sources. I usually buy them on eBay.
    AV8TOR's Avatar
    Dec 2008
    Fort Worth TX
    211
    My local Leslies store ordered one for me,
    Polaris 280 robot
    Pool Calc user
    New2Me's Avatar
    Jun 2008
    SW Indiana
    322
    Brad coated with Dip-IT for tool grips, or RTV silicone(gasket maker)?
    22 x 40 IG vinyl lined, 23,570 gal.
    1 hp. Pac-Fab Challenger pump 300# sand filter
    Intex 8110 SWG, Hayward CL220 offline feeder
    Hayward 250K Btu gas heater
    Aquabots
    AV8TOR's Avatar
    Dec 2008
    Fort Worth TX
    211
    Quote Originally Posted by New2Me
    You would be better off using shrink tubing. RTV and the Dip-it type coatings are not that slick like the teflon bar and might create drag against the container reducing the spin.
    Polaris 280 robot
    Pool Calc user
    Guest
    Shrink tubing cannot crate an impervious seal.
    AV8TOR's Avatar
    Dec 2008
    Fort Worth TX
    211
    Quote Originally Posted by waterbear
    No you shrink tube over the silicone job to provide a less friction spinning surface than the silicone. I still suggest you get the right bar as they are so cheep.
    Polaris 280 robot
    Pool Calc user
    Since I am a gadget person...this do it yourself stirrer thread caught my attention. My wife is a computer guru person...and upon request delivered to me "the required" dead hard drive and a fan. After removing the magnet from the drive I started positioning it on the fan hub. I attached it with a small piece of scotch tape. After 5 slight adjustments we hit the sweet spot and almost no vibration. I secured the magnet with several drops of superglue (hobby grade). I used an old CD for the cover. For the stirrer bar I used a small brad cut to 3/8". I used some sewing thread and wrapped it around the center of the brad to create a ridge in the middle. That was secured with a little superglue and activator. Next I covered the brad (with the thread in the middle) in food grade silicone and then slipped a piece of heat shrink over it. After shrinking and curing time...I cut it down to 1/2" total (1/16" past each end). It is smooth and sealed and the ridge in the middle is obvious.
    For power I used an old power supply that used to fit.....something 12 vdc output, 500ma...wired it and secured everything.
    The testing went perfect the first time! The ridge on the bar worked great and is silent in operation. Actual work time on this was about 30 minutes...and another 30 for prep and clean up. Before I started this project I checked with Kathy and she assured me we could afford to purchase one already made... However, I opted for the DIY project. My thanks to everyone on the forum for the great info!
    Time spent on project: 1 very gratifying hour
    Total parts purchased: Zero
    The Satisfaction of DIY: Priceless
    Travis & Kathy
    16x32 AGP (extra return outlet installed), Pentair Dynamo Pump (1.5HP, 60+ GPM), Sta-Rite Crystal Flow Sand Filter (300 lb), Clear Diamond Solar Blanket & Reel, Pool-Skim
    Aqua Trol SWG (also controlling the pump), TF Test Kit. (Everything self installed, up and running on 08/02/09)
    Enjoying the TFP site and appreciating the infinite knowledge of it's members... and I'm slowly learning how to maintain our new pool the BBB way!
    Four Winds Spa (love the tub...hate the filtration system). Best water quality in four years using the BBB method
    Jul 2007
    Suwanee, GA
    528
    very cool. Here is one I built some time back and it still works like a champ.
    homeade-stirrer-t3619.html
    Gary
    21k gal SW, IG Gunite PebbleSheen, 1HP Jandy, Jandy 340 filter, Polaris 280, 17' fiberglass slide w/ 2HP pump.
  20. Back To Top    #20
    Crabboy,
    Thanks! Nice "project box" on your stirrer I will probably leave mine "naked" for the sake of space. Has anyone tried to run one of the 12 vdc fans on a 9 volt battery? I think I may give that a try on another fan. That would make it more compact and portable. Thanks again...
    Travis
    Travis & Kathy
