Results 1 to 8 of 8
Thread: cloudy ubove ground pool
    Apr 2015
    bowling green, KY
    4
    Had my water tested today and all was good except it is very cloudy. They wanted me to buy pool tonic to clear it up for 30.00. What would you advise using .
    Pro Series Above ground vinyl pool , 20 x 48 , pump type is F2000C, filter system is cartridge( SFS2000)..Second year, looking for easy care, while not expensive. Hope to use the BBB method.
    I love working on the pool and enjoying it. I have 6 children, three still at home. we have very busy lives with school and soccer.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,602
    Re: cloudy ubove ground pool
    Welcome to the forum. I would advise you give us the test results you have and consider ordering one of our recommended test kits.
    Apr 2015
    bowling green, KY
    4
    Quote Originally Posted by woodyp View Post
    total chlorine: 9.2
    Free " " : 9.2
    ph: 7.7
    Tot Alk 135
    Tot Hardness 154
    Added muriatic acid to get ph down a little. Will get a good test kit as soon as I can afford. Husband was just let go from his job and we are in a tight place right now
    Apr 2015
    bowling green, KY
    4
    Just tested water again. Hardness is high (1000), total and free chlorine are both high (10), ph good.(7.4) on my test strip. any suggestion on how to get rid of cloudyness.
    Apr 2015
    bowling green, KY
    4
    No suggestions on a cloudy pool. I am dieing here, please help....
    Jun 2014
    15,144
    Good morning Carmen. It looks like you are trying to get some numbers from your test strips. So you may think chlorine is high, when actually it is not. So the cloudiness could be from an algae bloom, or could be from something else in the water, but the proper test readings are what will tell us for sure. The proper test kit (i.e. TF-100 – link below) is the foundation of your pool care. Why this kit? We've learned through personal experience that you cannot reply on pool store testing, test strips, or simple over-the-counter kits. They simply do not read Free Chlorine (FC) or Cyanuric Acid (CYA) levels accurately or to the high levels we need. If you do not have a TF-100 or Taylor K2006 test kit, it should be your #1 priority.
    Please try to obtain either the TF-100 or Taylor K-2006 from TFTestkits.net so we can help you. Also, take a peek at the Pool School - Chlorine / CYA Chart which might explain why an FC of 10 is not always a bad thing. The FC must match your current CYA, and those test kits we recommend will give you those results.
    Hope this helps you. Let us know if you have any more questions. Have a nice day.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Hi Carmen,
    cloudiness is usually caused by the beginnings of an algae bloom.
    The other reasons is for calcium precipitation or addition of some of the pool store snake oils.
    In one of your posts, you report hardness (which is calcium) as 154 and then again at 1000. Thats just not possible as you have to add calcium for it to go up.
    anyways....
    Most lilely the cloudiness is due to algae, but hard to cofirm that without a proper test kit.
    However, the cure, is to kill the algae with chlorine and filter the dead algae out of the pool.
    Divin Dave,
    Mod Squad pooldv's Avatar
    DFW, TX
    24,496
    Welcome to TFP!
    +1 that cloudy is algae. Algae is caused by lack of chlorine in the pool in relation to the CYA level in the pool. Chlorine level is set based on CYA and the Chlorine CYA Chart. Always keep chlorine at or above target level.
    Get one of the Recommended Test Kits, I use the TF100 from TFTestkits.net.
    When you get it give us some test results and get ready to SLAM Your Pool.
    Here are some of my fave Pool School articles to read while you wait for your test kit.
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    Here are the Recommended Levels for your pool.
    Here are the Recommended Pool Chemicals and how to add them.
    Use PoolMath to figure out how much to add.
