Thread: Where's The Leak?
    May 2013
    Falls Church, VA
    41
    Where's The Leak?
    Yesterday evening I let out some water using the waist setting since it was pouring down rain. This morning the level looked low compared to how much rain we got. So, I replenished some not thinking much about it. Just now I looked out and the level was a good 5-6" less than 12 hours ago and enough to lose prime in my pump. The pump was still running. So, hopefully it's not toast. Clearly I've got a leak but where and what might have caused it?
    11.5k gal, IG Plaster (2001), 1.5 HP Pentair Ultra-Flow Pump, Purex Triton FNS Plus 60 sqft DE filter
    Thimble's Avatar
    Apr 2013
    Wichita, KS
    93
    Re: Where's The Leak?
    Did you set your valve back to filter after setting it to waste ?
    15x30 IGP; 20,000 gallons; plaster
    Hayward SP2607X10 Pump; Purex Triton Tagelus Sand Filter
    Hayward Goldline T-Cell 15 SWG; Aquarite G1 Control
    Southwest Spas 400 gallon hot tub w/ozone
    TF 100 with speed stir
    May 2013
    Falls Church, VA
    41
    Yep; I'm thinking (hoping) it might just be the spider gasket in the multi-port valve. In the recent past while in the waste setting I've seen "dirt" going back into the pool via the returns. I'm refilling the pool now and will confirm if the water is in fact going out the waste hose while the valve is in the filter setting.
