Thread: First test in South Jersey New Build!!
    karynkjd's Avatar
    Mar 2015
    Berlin, NJ
    325
    Pool testing
    Free chlorine 2ppm
    Combined chloroquine a 1.0
    Total
    Chlorine 3.0
    Calcium hardness 200ppm
    Total alkalinity 100
    Cya - never didn't see black dot
    Basic kit:
    PH 8.2
    Chlorine 1-2
    New Build started April 2015, 20x30x40 Lagoon Style Vinyl (indigo marble/blue granite), 27,500 GAL, IG, 839 square feet, 9' tanning ledge/baja shelf, 9' radial bench, 8' classic Waterfall, 3'6" to 8'Depth, Sand, Pentair 2 speed Superflow 1 1/2 HP, SWS, 2 Pentair LED Intelibright 5 G lights, Pentair Legend Platinum II pool cleaner, 2 skimmers, 3 returns. 1080 square feet of Silver Slate stamped concrete.
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Re: First test in South Jersey New Build!!
    I think you know this but I will lower the pH to 7.2, raise the CYA to 30 and slam, how is your water?
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
    Donldson's Avatar
    NW Ohio
    2,896
    Congratulations on the new build! We would love to see some pictures if you get a chance
    Test results sound like a typical fresh fill. The CC is probably just from the water that filled it, a lot of municipalities chloromines nowadays. So your next steps are to adjust your pH and get some stabilizer in there. How are you going to be chlorinating your new pool?
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    karynkjd's Avatar
    Mar 2015
    Berlin, NJ
    325
    They put about 20 bags of salt in the pool (pb) before I even got home. Since then we had two storms and they emptied half the pool to do a repair on the step.
    I think I have to get the cya even higher than 30
    Right? Since salt water...
    The pb gave me stabilizer - I have touched any of their chemicals. There is something for everything
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    well if you have to slam I will not go higher than 30, later after you pass the slam of course I will raise CYA up to 70
