Thread: Hayward H300 Heater problem no code
    Jul 2015
    hamilton
    2
    Hi guys I have a hayward 300fdn natural gas heater about 5 years old. I had it running fine. This morning it was still running, the pool was at 87 degrees. But when I checked it this afternoon it had stopped. The service light is on and in the display it is showing the number 56. As if 56 degrees. It will not change mode at all it is stuck in pool mode. I tried restarting it, I unplugged it for about ten minutes and restarted it and it is still stuck on the pool mode and 56. The only thing when I first restart it , it will flash and display the degrees of water temp at 86 and the stops and service light and 56. Any help would be greatly appreciated thanks.
    ps0303's Avatar
    Jul 2011
    FL
    3,684
    Re: Hayward H300 Heater problem no code
    Are all the numbers displaying correctly? Meaning, maybe the display portion of the board is shot and the 56 is actually a set of letters. I've had people clal me saying their display says "5S" but it's actually "SF" as the digits on the display are messed up. Also, if you can't change the mode, then I would have to guess the board is shot and you need to replace it.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Jul 2015
    hamilton
    2
    [QUOTE=ps0303;867818]Are all the numbers displaying correctly? Meaning, maybe the display portion of the board is shot and the 56 is actually a set of letters. I've had people clal me saying their display says "5S" but it's actually "SF" as the digits on the display are messed up. Also, if you can't change the mode, then I would have to guess the board is shot and you need to replace it.[/
    Thanks for your reply. The board numbers are perfectly fine. I also just got in from giving it a good clean and checked all the wires and harnasses. They were all fine. I wiggled the igniter. I don't know what I did but it's coming on now but the display is still on 56 and it will not change modes and service light is still on.
    18x38 inground pool. with a hayward 300 heater and hayward filter and century pump.
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    426
    My guess is the reading is really Sb rather than 56. This means one of the keys on the key pad is stuck. if you can not get the key to unstick the key pad needs to be replaced. FDXLBKP1930 is the part number. If under warranty, call our tech line and they will help. 908-355-7995
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    poolside@haywardnet.com
