Results 1 to 9 of 9
Thread: Intex saltwater upgrade
    Hi all!!
    I have an intex salt water system with a cartridge filter. Id like to upgrade to a sand filter. I have a chance to buy a 16" intex sand filter pump.
    Since I already have the intex saltwater system, could I unplug my cartridge filter and adapt the sand filter pump?
    My other concern is both pumps running?
    Has this been done before ?
    my pool is a rectangle 18x9x52"
    Or 4500 gallons
    Thank you
    Tim
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Re: Intex saltwater upgrade
    Good choice , not need to run pumps in sequence the 16" come with a 0.95 hp motor, more than enough...
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
    I still need to run the saltwater pump though in order to generate chlorine right?
    Should I disable the pump on the saltwater system as well as the cartridge filter?
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    if that is a combo, I am not sure but I think is not needed, tray with the combo pump off and see if the swg is working, look at the settings for the combo, I think they can work separated
    This is the salt system I have and the pump I can get for cheap.
    I'd like to integrate the two.
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    yes, thats the discontinue sand filter from intex and the combo swg pump, look at the book from the combo I think there is a setting where you can run them separated in any case I will remove the filter in the combo
    I would still need to plug both pumps or systems in is that right?
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Quote Originally Posted by bennett.tim72 View Post
    Yes, or if you are willing, there is a new SWG in Amazon for $99 and sell the combo in Craig list
    It's better to run this system separated, this is how is recommended here
    I live in Canada, the shipping is the same price as the unit arrrg!!!!
    I may try to either disconnect the cartridge filter underneath the unit or connect the two together.
    The separate swg has a flow rate of 1650. I figure I should be able to connect the two together and take out the cartridge
