Results 1 to 10 of 10
Thread: Stenner Install and Bleach Storage Tank
    Inflatableman1's Avatar
    Jun 2015
    Playa Coronado/Panama
    62
    I'm leaning hard towards a Stenner for chlorine addition. I only have 5.25% bleach available so I have to do a fair bit of hauling. We also travel a fair bit. I would like to simplify this with automation. I have high power costs and soft stone in my pool so will not be going the SWG route. I also want something simple and easy. Here is a picture of all my automation.
    I run my pump on the timer a minimum time each day just to keep the power bill down. We still quite often run the pump when we are in the pool, or even in the yard, just for the water noise with the overflow edge. So no shortage of pump run time, but only a couple of hours per day on the timer.
    I think bleach usage will be in the neighbourhood of a 1 to 1-1/2 gallons a day on average. Let's say worst case 2 gallons if I buy a weak batch.
    A Stenner 45MPHP22 (high pressure, fixed rate) does about a gallon an hour. So three hours of pool pump run time will easily cover worst case two hours of Stenner run time.
    So my plan will be to run my Stenner with an independent timer (such as the popular Woods one I have seen here) while my pool pump is running. It is my understanding that I can add another set of pins to my existing Intermatic timer to enable me to run my pool pump twice in a 24 hour period. I can then split my chlorine injection over two periods. Does anyone see any major issues with this?
    Next, for a tank... we bought one of these for dog food recently (works well btw, 35 USD at our Costco equivalent):
    Vittles Vault
    The site says "The Vittles Vault is manufactured from FDA approved high-density polyethylene (HDPE), which is used throughout the "human" food industry". Does anyone know if this would be capable of containing chlorine? The size and shape is nice for the space I have to work with, and if I want to increase storage I could just add another side by side and split my suction. The wide opening would be handy for filling, no funnel required and such.
    So that's my base plan at the moment. Heading to Canada next week for a couple of weeks and will hand carry the pump back (and some TF goodies). Any input is greatly appreciated.
    I forgot to mention that everything will be indoors.
    Ryan
    41' x 16' x 5' IG, 25 000 gallon, cement, tile w/epoxy grout. Overflow/negative edge style. Pentair 4048 DE, Hayward 2 hp Single Speed, Pentair 320 Auto Chlorinator, 1.5 hp Blower f/Jacuzzi, TF-100, city/well (in pool) water option. Located in Panama.
    Dec 2014
    Riverside California
    482
    Re: Stenner Install and Bleach Storage Tank
    Stenner has a 15 gallon tank that you can also mount the pump to. Google stenner pumps and get to their website. The tank you mention looks like it has way too many points that could leak, and with bleach you do not want that. You also want one opening at the top to pour bleach into.
    38000 Gal, IG, Plaster, 20' x 40' x 10', Attached Raised Spa, Intelliflo VS 3 HP (011018), Pentair Quad DE 60 Filter, Raypak (Rheem) 400,000 BTU (407a low Nox), Easy Touch 8 upgrade, Screenlogic 2 with wireless, IS-4 Spa Side Remote, Stenner 45MPHP10 w/15 gal tank, Intellibrite 5g (3), Dolphin Triton Plus robot with PRO remote, Water Tech Catfish handheld vacuum for spa, TF100 with SpeedStir.
    Apr 2015
    Tucson/AZ
    90
    I have zero experience with indoor pools. Someone else should chime in.
    (1) If this is an indoor pool, why would you expect the chlorine consumption to require 1-2 gallons of chlorine (5%) per day? Your pool is listed in your signature line as being 25,000 gallons. I have a 20,000 gallon outdoor pool in Tucson with no shade and use at most 50-60 oz of 10% chlorine with full sun and air temps of 102-107 deg F all day. I would expect your chlorine consumption to be much less. On cloudy days, I use very little chlorine.
    (2) Have you been manually adding liquid chlorine? If not, would suggest you do that for a week or so to understand your usage before settling on pump size, tank size and pump on time.
    (3) See no issue with your plan, although agree with gary300 on ensuring a tank with good integrity.
    Gary
    20,000 gal IG Plaster Irregular Shaped Pool (1987), Hayward SP3400VSP Ecostar Pump, Hayward Pro-Grid 60 SqFt DE Filter, Hayward Pool-Vac Ultra, TF100, Speed Stir, Stenner Pump & 15 Gallon Tank, Oasis Z5, and LA Spas H.E.E.T Model
    Jun 2015
    62
    The Stenner installation will be indoors.
    I will not be shipping a Stenner tank to Central America.
    Ryan
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    I see no need for the additional timer. It is just a point of faliure for the two timers to get out of sync. When I did my Stenner Pump Install I just slaved off the primary timer so that anytime the pool pump is running the Stenner is running. The Stenner has an on/off switch on the top so that you can shut it down manually if you want to.
    Support the site
    Jun 2015
    62
    Hi Tim. Is tying the Stenner to the primary timer reasonably simple? I guess I was thinking that I would have the primary pump run for a bit after the Stenner shut down. But maybe not necessary.
    Ryan
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by Inflatableman1 View Post
    If the pool timer/pump and the Stenner are boththe same voltage then yes, its a piece of cake. Look at my photos and you see the wires coming off the timer going to a receptacle that the Stenner plugs into.
    Support the site
    Apr 2013
    Sacramento, CA
    2,769
    Yes it is ok to use the same timer but you need to use the adjustable rate pump not the fixed rate pump. If you use a separate timer you can use the fixed rate pump.
    Jun 2015
    62
    I am leaning towards fixed rate and two timers. My timer is 220 and I am interested in the 110 Stenner.
    Ryan
    22,550
    I like the two timer setup, however, I recommend getting a timer with two (or more) circuits that can be independently programmed. That way they can't get out of sync. the Intermatic ET1125C or the P1353ME or P153 would work great.
