Results 1 to 19 of 19
Thread: My readings, and trying to get the water clear.
    Apr 2015
    porter Tx
    26
    My water is cloudy, I've been able to keep the alge at bay but I cannot seem to get the water clear. What specific solutions do you recommend to solve these reading issues and clear up my water?
    Here are my readings,
    FC 6.5
    CH 175 ppm
    TA 80
    PH 7.2
    CYA none, I could still see the black dot with he cylinder full, I know how to take care of this item though
    I have read that CH being to high would cause cloudy water, what about it being to low?
    And thanks again, u guys rock!
    Above ground, vinyl liner,
    15,000 gal.
    Hayward pump, sand filter, TF 100 test kit
    Jun 2014
    15,205
    Re: My readings, and trying to get the water clear.
    CH can impact the water at times, but I kind of doubt that is your situation. Interesting that your FC is 6.5 with no CYA. That FC must be getting "ripped" out of the pool with our TX sun and no CYA to protect it. Since you know what to do about the CYA, just shoot for 30 for now since you will probably need to SLAM.
    Need to ask though ... was your water filled with city water or well?
    Also, you didn't post a CC (combined chlorine) reading, but that would be a good one to know. I would suggest doing an OLCT test tonight. Basically once the sun goes down, add enough bleach to get your FC to about 10 or so. Let it mix for about 30 min to confirm your FC before bed. Then BEFORE the sun hits it, check that FC. We want to know if you lose more than 1 ppm of FC during the dark hours.
    That test along with your CC reading tomorrow will give us a good indication of what to do next. Have a nice evening!
    Apr 2015
    porter Tx
    26
    My cc is 1
    15,000 gal.
    Apr 2015
    porter Tx
    26
    And we're on a well
    15,000 gal.
    Apr 2015
    porter Tx
    26
    I keep editing my signature to add I'm on a well, but it does not seem to take
    15,000 gal.
    Apr 2015
    porter Tx
    26
    Ok I may be posting the free chlorine and the Cc wrong.
    I got:
    CC 1
    chlorine drop test 5.5
    Added them together to get 6.5 TC
    15,000 gal.
    Jun 2014
    15,205
    ha ha. That's okay. We'll figure out the sig later. Well, a couple things. A cc of over .5 tends to indicate you have a little more organics in the water than we would like to see. There's a battle between the good chlorine and algae which results in a higher trash chlorine (cc) level going on right now in your water, and we need to help the good (FC) overcome. You can still do the overnight (OCLT) test to confirm, but I would be surprised if you didn't lose more than 1 ppm during the hours of darkness.
    So you should probably be prepared to do a SLAM. That page will tell you everything you need to know. The key - MAINTAIN the higher SLAM FC level. Since you appear to have no CYA right now, you would increase FC to a SLAM of "10". But make sure you get that stabilizer going too.
    Also, take a water sample to your local pool store. Just nod and smile when they tell you their advice, but bring back your readings on metals. We need to know if you have a significant amount of iron or any other product in your water. Sometimes that has an effect as well.
    Apr 2015
    porter Tx
    26
    Ok, I don't understand what 10 means on the chart. I'm sorry to be so basic with this buts its all new to me!
    Is it 10 lbs??
    15,000 gal.
    Jun 2014
    15,205
    Sorry. 10 is the level (reading) of FC. SO you will need to add enough bleach to stay at a reading of 10 ppm per your TF-100.
    Using the Poolmath calculator http://www.troublefreepool.com/calc.html, based on a 15K pool with a "current" FC of 5.5, that means you need to add 1 Gal & 2 cups (140 oz) of regular bleach to your water to get to that target of 10 ppm.
    Once you add that amount of bleach, let the water mix for about 30 min and check again to make sure your FC level is at 10. Slightly higher is okay, but not lower.
    Then check once more when the sun goes down to make sure your FC is at 10 ppm before bed. Then BEFORE the sun hits the pool in the morning (YAWN), check that FC reading. We want to know if you lose more than 1 ppm of FC during the dark hours. Example: Before bed the FC records at 10 ppm, then when you wake up it is 9 ppm.
    Jun 2014
    15,205
    Minor correction from above - if you use grocery store 8.25% bleach, it would be 3 quarts & 1 cup (100 oz). But by now, since the time you posted your initial FC reading, I'm sure some chlorine has burned off. Just round it up to one full gallon of regular bleach.
    Apr 2015
    porter Tx
    26
    I currently have some liquid shock. So I can use 1/2 gal right?
    15,000 gal.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Sure, plug the numbers in to Pool School - PoolMath, usually liquid shock is 10% or 12%, you can change the percentage in the calculator to tell you how many ounces to add.
    Jun 2014
    15,205
    Good morning! Just checking back to see of you had a chance to do the overnight FC test? FC test before bed, and FC test result before the sun came up?
    Apr 2015
    porter Tx
    26
    No I did not. Last night got a little busy around here, and I let the pool get away from me. I think the root problem here is me! I'm still keeping up on my readings today and I will keep my chlorine up to avoid over growth of the nasties. And I will give it a go tonight
    15,000 gal.
    Jun 2014
    15,205
    Hey, at least you're honest. ha. Have a great day/weekend. When you're ready, just review the notes above. And since you're on a well, don't forget to have a pool store check you water for metals next time you're running around. Enjoy!
    Apr 2015
    porter Tx
    26
    I will defiantly do that! And thank you so very much for for all your help! I finally feel like I have an understanding. Of the chemistry project that is our pool!
    15,000 gal.
    Apr 2015
    Quinlan, tx
    811
    Busy ladies can figure this out too. Don't be too hard on yourself and once you know what your pool needs on a regular basis, you can compensate when you get too busy. . I've been there, often.
    Lisa P.
    26,000 IG, pebble tec, flagstone, pentair Triton II TR100 sand filter & VS+SVRS 3hp multi-speed pump, Intellichlor IC-40 SWG, Pentair Booster Cleaner, spillover spa, waterfall, Taylor K-2006 testkit
    [It is better to know how to learn, than to know. - Dr. Seuss[/I]
    DFW, TX
    24,502
    Quote Originally Posted by dawniellewesterman View Post
    Click SETTINGS upper right
    Click EDIT SIGNATURE lower left
    Type in signature info
    Click SAVE SIGNATURE at bottom
    Apr 2015
    porter Tx
    26
    Thank you!!
    15,000 gal.
