Thread: CH Is Crazy High!
    Apr 2014
    Orange County, CA
    2
    CH Is Crazy High!
    Hi All,
    First-time poster here. I'm super frustrated! I had a new pool built and filled just last April 2014 and have had a pool guy taking care of it for this past year - I have, however, been reading on this board a lot over the last year and am generally familiar with the basics of ABC's of pool chemistry (I know, I know, I should've just taken care of the pool myself entirely) Anyway, I've had tons of white calcium flakes coming out from the SWG the last month, and finally, today, my pool guy tells me my CH is at 800!!!! and my only option is to really drain and re-fill, which in SoCal right now is tough with the drought, etc. My pH and TA have generally been good (around 7.5 and 80-100, respectively). Also, he just tested my fill tap water today and it's only 250. What do I do?? Does my new plaster have something to do with this super high CH too? My biggest concern is that after only a year of filling the pool and doing what I feel was a decent job of keeping the chemistry in balance, my CH is out of control and if I have to refill, then how do we keep the CH under control going forward so this isn't an annual occurence?
    Thanks for any suggestions - I love reading posts on this forum and all the nice people here!
    14K gal, 3 1/2 ft to 5 1/2 ft gunite/plaser, 3hp Pentair Intelliflo Var Speed pump, 2hp Pentair WhisperFlo pump for waterfall/slide,
    Pentair Intellichlor IC40 SWG, Pentair 60 sqft DE filter, Pentair MasterTemp 400K BTU heater
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,410
    Re: CH Is Crazy High!
    What test kit did he use to get your numbers?
    Do you have a good test kit yet?
    New plaster can mess with numbers but I THINK that after a year the numbers should be settled and balanced.
    Kim
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    from the sounds of it ask your "pool guy" if he has been shocking once a week or month with cal-hypo.. that is the only way I can think your CH would rise from 250 to 800...
    Sounds like the "pool guy" owes you a truck load of water
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    What has he been using to chlorinate and "shock" the pool? I have a guess, but would like the answer....
    Reverse Osmosis is available in your area, but probably expensive.
    Support the site
    Apr 2014
    Orange County, CA
    2
    I have a SWG which is really the only chlorinator we use - and I occasionally add bleach after heavy usage. I don't think we've really had to shock it, but I could be wrong. I know he likes to use dichlor to chlorinate - could that be it? I'd love to hear your guess
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    800 isn't so bad. That's what I got the last time I tested. Keep pH down at the lower end of the safe zone and keep TA around 70 and it's fine. Plug your numbers into poolmath and look at the CSI. Play with individual variables and see how each affects things. As long as you're at 0 +/- .3 there is no worry about the plaster. The SWG will need more frequent cleaning, but the alternative is a five hundred dollar water bill....
    I would suggest you get your own test kit. Also a speedstir. My CH readings went down 200 just by using the speedstir to test. And with a SWG, you need salt test strips or drops. It's all available at TFTestkits.net
