Thread: Adding large amounts of liquid chlorine question
    May 2015
    Prairieville, LA
    6
    I've read on here that it is best to put your chemicals into the deep end of the pool because that's where the returns are located. When adding large amounts of liquid chlorine could this bleach or discolor my plaster? If so, is there a better method? Or I don't have anything to worry about. It just concerned me. Thanks
    Jun 2014
    15,059
    Re: Adding large amounts of liquid chlorine question
    You will routinely see us posting that we pour contents "slowly" near a return with the pump circulating/mixing the chemicals for at least 30 minutes. Some liquid chemicals are heavier that water, so even brushing can help to ensure it get dissipated. But not everyone's returns are at the deep end. My return jets are in the shallow end, and my skimmer in the deep end. Still, if you follow these procedures you should have no problems at all. This applies to all types of pools (plaster, fiberglass, vinyl, etc).
    30,414
    +1 what Texas Splash said. Deep End isn't important. In front of a return is VERY important.
    May 2015
    Prairieville, LA
    6
    My returns are in my deep end. I have a sitting ledge the whole width of the pool in the deep end as well that is only 18 inches deep. This is why I am so concerned. I guess I'll just pour it in more towards the middle.
    Mar 2007
    San Rafael, CA USA
    12,082
    Yes, pour more towards the middle of the pool. You can also lightly brush the side, shelf, and bottom of the pool in the area where you've added chemicals. That will help a lot towards ensuring thorough mixing.
