Thread: Intex 26' pool first year, rust starting on many T-joints
    May 2015
    Southern Illinois
    49
    I'm not sure what to do about this, it hasn't been 90 days since I bought the pool and I just noticed rust starting on probably 10 out of 26 T-joints. Is this normal for intex pools? What can I do about it? I mean, I am really not prepared to take my entire pool down and apart to replace it right not but I also don't want to be left with a pile of rust next year. Has anyone had this problem? What is intex customer support's solution? Any suggestions?
    26' Intex 17k gallon above ground pool. 3000 GPH intex sand filter. Taylor Tech. k-2006 Test kit.
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    Re: Intex 26' pool first year, rust starting on many T-joints
    that's not good, its under warranty so I would call them and see what they are willing to do. that's a big pool to have to drain, refill and rebalance. might be worth sanding off the rust and applying a outdoor paint/sealant
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    May 2015
    Southern Illinois
    49
    Yea, I finally got everything with the pool sorted and am at that blissful point of just adding about 2ppm of FC each night and smooth sailing and now another problem. Bleh. It makes me worry about what is happening where I can't see if the materials weren't properly finished or treated. I will see what they say about it and if it's ridiculous I will try to sand it off and seal the rest of them. I know nothing about this, what kind of sealant would I use?
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    My husband has used a paint for rust on automobiles that turn the rust into hardened material. Will retry to find the name of it when he gets home.
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,520
    For the price, I consider I've gotten my money's worth if I get three years out of one. I leave mine up year round, and I'm starting to get a little rust this year, its second. I'll take a rattle can of Rustoleum to it at the end of this season.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
