Thread: Multi port leak?
    cood60's Avatar
    Jan 2012
    Virginia Beach
    82
    Multi port leak?
    I have noticed that my Multi port seems to be leaking into the section of 1.5" waste line. Because I keep that waste line valve closed off about 2 feet from the multiport, I can tell it fills with water over a period od several weeks. I also noticed that the water in the sight glass is yellow/green as though maybe the stagnant water in the waste line might be somehow leaking back in to the glass.
    1- Is it normal to have that valve leak in to the waste line
    2- Is it possible for it to back up in to the multi port sight glass or even the pool itself?
    3- Am thinking I will change the spider gasket first
    4- If it still does it, what else can it be?
    Thanks for any advice
    22'x40' IG, Freeform, 26K gal, Vinyl liner pool(2011), three returns plus two step jets, one slide, two skimmers, two LED lights, Stamped Concrete with Aqua PL-Plus Automation panel, Pentair Intelliflo VS, Hayward Pro Series High Rate Sand Filter 500lb, Hayward Turbo Cell T-Cell 15 (SWG) , Dolphin Robotic Pool Vac, Hayward Heat Pump.
    22,551
    Re: Multi port leak?
    Theoretically it should not leak into the waste line at all, but if you're talking filling a 2' section of 1½" line over a period of two weeks then it isn't much of a leak, and I'd likely dismiss it as trivial.
    If it filled up the line in a day I'd be concerned and the first step is to replace the spider gasket.
