Thread: Handling chemicals
    Desiato's Avatar
    May 2015
    Catalunya, Spain
    70
    Handling chemicals
    First off, just wanted to say that with the help of this forum I've resolved a long running problem with my pool and I'm now fully up and running the TFP way.
    The backbone of the TFP way is to use bleach and acid rather than shop bought tabs and PH adjusters and there's a plethora of information for calculating how much of each you need to use and when to use it. What I'm noticing though is a lack of proper handling advice hard coded into the TFP way. The ABC's of pool water chemistry doesn't mention it and in The Pool School Index there's no H for handling, no A for Acid or even C for Chemicals. I've just read the thread here about a guy who damaged his eyes and had to go to hospital despite wearing several items of protective clothing. I was shocked because I am pouring in acid straight from the bottle without really giving it much thought because I havenít read anything on here to guide me on what precautions I should be taking. Sure there are forum posts if you specifically go looking for them but this kind of info needs to be up front and centre because, as I say, handling bleach and acid are the cornerstones of the FTP way.
    By chance I stumbled across a post that said "don't store your acid next to your bleach" (I was doing exactly that) and don't store it next to metals that could corrode. I also stumbled across a post that said....now what was it....something about not using your now discarded puck floater for other types of pucks because there will be a bad chemical reaction between the new and the old chemicals....you see the problem? This was an important bit of info and I've now forgotten what it was and it's not mentioned anywhere in the Pool Index or other guidelines. It might have been something to do with Vitamin C come to think about it. I know there has to be some common sense and logic says ďbleach and hydrochloric acid are bad, níkayĒ but I think itís important that Health and Safety are covered in the Pool School and Pool Index as this is where all newcomers head to first.
    So my suggestion is to have a bigger section on the chemicals used and the correct methods for storage, handling and administering. I think this is required to make sure there are no more episodes like the one that happened to Michael1.
    I'm a Brit abroad living in Northern Spain near Barcelona.
    In Ground Plaster 15,500 US gallons.
    Certikin Sand filter (SPHS640) with 0.6mm -1.2mm glass media.
    Astralpool Victoria Plus 38774. 16,000 l/h 0.76 kW (1 HP) 230/400 V III
    LaMotte FAS-DPD 7022-01
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Re: Handling chemicals
    Although all the storage and precaution information is on every single item that is recommended to use, most people don't read them. Probably wouldn't be a bad idea to have a safety/use/storage recommendation section more spelled out.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Inflatableman1's Avatar
    Jun 2015
    Playa Coronado/Panama
    62
    Out of curiosity, did you follow the proper storage and handling instructions as outlined by the packaging and MSDS of the MA You were using?
    Ryan
    41' x 16' x 5' IG, 25 000 gallon, cement, tile w/epoxy grout. Overflow/negative edge style. Pentair 4048 DE, Hayward 2 hp Single Speed, Pentair 320 Auto Chlorinator, 1.5 hp Blower f/Jacuzzi, TF-100, city/well (in pool) water option. Located in Panama.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    More wording on the dangers of MA fumes could be added to the Recommended Pool Chemicals section.
    In the US, it's certainly more of a consumer beware and be self-informed situation when it comes to chemical products. If a consumer does as they're supposed to and read the precautions and warnings on the container or with documentation that comes with the product, they'll know how to handle them. The problem is, many people do not and are in a hurry to get things fixed, dump things in the pool with reckless abandon.
    A section, or footnote in each Recommended Chemical in Pool School that lays out basic dangers of each recommended chemical and also lists some incompatibility concerns would be a nice feature. Do I think it's required? No. However, we are interested in helping people take care of their pools in a reliable, cost effective and safe way because it's the people that come and keep coming back that are important. It's still a good idea.
    Isolated Spa - 345 Gallons
    Desiato's Avatar
    May 2015
    Catalunya, Spain
    70
    I was also thinking along the lines of:
    Where to pour the chemicals - in front of a return, at the deep end or all around the perimeter?
    What speed to pour them in and what happens if your pour in too quickly
    How to pour them in - what distance above the water? Should I almost submerge the bottle before pouring?
    What gloves (if any) should be worn?
    What eye protection (if any) should be worn
    What to do if you accidentally spill some on you (run to the nearest tap or jump in the pool?)
    What chemicals can and can't be stored together (and why) and at what temperatures. Some of that will be on the bottle but does it say don't store Hydrochloric acid next to bleach and metal objects? mine doesn't. If I hadn't stumbled upon this in a forum post I wouldn't have known any better so quite how this could be considered irrelevant (or not required) in the TFP guidelines I'm not sure.
    So not just the general health and safety on the side of the bottle but how it relates to the real world situation of when it is being used in a swimming pool.
