Thread: Brand of Cyanuric Acid?
    Snap96's Avatar
    Jun 2015
    Chicago, IL
    39
    When it comes to stabilizer/conditioner/CA, are there particular brands to look for or stay away from? I'm guessing that any brand would do as long as it states that it's 100% CA.
    We just had our pool installed so I'm still learning.
    Paul
    Barrier Reef Whitsunday 35' IG Fiberglass...17,500 gallons...Hayward H250 Heater...Hayward Max-Flo XL 1.5hp Pump...Hayward 24" Pro Sand Filter...Hayward Aqua Plus SWG...Taylor K-2006 and K-1004 Test Kits...Built Spring 2015...Use village well as fill water
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,429
    Re: Brand of Cyanuric Acid?
    They are all going to have some filler. As long as it is more than 90% CYA it should be fine.
    Love TFP? Become a
    TFP Supporter!
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    I'd be inclined to recommend the HTH brand of CYA. It's a finer granule than most types I've used and dissolves more quickly as a result. Just make sure the sock you put it in has a tight weave so it doesn't leak out. I found mine at Home Depot pool products section. 97% I believe.
    Isolated Spa - 345 Gallons
    Snap96's Avatar
    Jun 2015
    Chicago, IL
    39
    Great...thanks for replying.
