Thread: Having no luck with the intake cover and gasket it is leaking something terrible ....
    Jul 2015
    Derry,Pa
    2
    We have to patch the liner and recut to hopefully get the intake gasket to seal and not leak ...Just wondering if anyone has some hints /ideas on how to cut the liner ,the first time we used a butterfly gasket and then we cut an X in the middle of the hole and pushed the intake thru the hole in the liner , this time we have 2 rubber gaskets and a paper one they told us to place 1 rubber one on the inside ,one on the outside along with a paper gasket and that should be good .We are ready to pull out our hair ....any help would be appreciated
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,557
    Re: Having no luck with the intake cover and gasket it is leaking something terrible
    Can you post a picture of what you've done? I'm having a hard time comprehending it.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
