Results 1 to 13 of 13
Thread: The Taylor #4088 CYA test tube the same as the Pentair #79 S/N R151226 CYA test tube?
    Jun 2015
    Glendale, AZ
    156
    Is the Taylor #4088 CYA Test tube and the Pentair #79 S/N R151226 CYA Test tube the same tube?
    The pictures I find look the same, I searched here as well as Goggle for the answer, anyone here know?
    Thanks
    Valley of the Sun, Arizona.....10k gunite/pebble (Re-surface March 2015) w/in floor Caretaker 99 cleaning heads -- Pentair FNS 60 DE filter -- Pentair IntelliFlo Variable Speed for pool -- Pentair Wisperflo 1 HP for boulder waterfall...Taylor K-2006 & Taylor K-2006C kits
    Apr 2013
    North OKC Area
    300
    Re: The Taylor #4088 CYA test tube the same as the Pentair #79 S/N R151226 CYA test t
    Don't know but I think they all use the same reagent, so the end result should be pretty much the same.
    17,100 Gal 27' x 52" AGP steel wall vinyl; 44gpm Cooper sand filter; Hayward 1hp sp1580 single-speed; 1.5" plumbing, 1 skimmer/jet, inline chlorinator.
    Chlorine / CYA Chart | SLAM Process | Chlorine cost/fl. oz calculator
    30,421
    Completely different. What pictures did you find that look the same? The Pentair uses a sliding dot apparatus that does not really resemble the Taylor view tube.
    Jun 2015
    Glendale, AZ
    156
    Taylor's description......."4088 Cylinder, CYA w/ movable slide to measure CYA, plastic"
    I am talking about the sliding dot on both....if you search the Taylor web site (part #4088) it looks 'identical' to the Pentair #79 S/N R151226.
    The pictures of the Pentair model are on Amazon as well as many pool supply web sites and the picture of the Taylor is on the Taylor web site.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Just curious, why are you looking for these types when you list the 2005&6 Taylor kits in your sig?
    Essential Links:
    Jun 2015
    Glendale, AZ
    156
    Quote Originally Posted by Patrick_B View Post
    For myself, if this test tube will be more accurate for me, then that is what I want. This test for myself is hard to determine exactly how much CYA I have and I want to be as accurate as I can, with CYA being such an important part of maintaining ones pool.
    I have tried the K2005/K2006, and tube from the TF100, now I will try this one.....
    It seems one can be off as much as 10% or 20% or even more.....I tried the Taylor 50/ standard as many have, I get 30, that is off by 40% for myself....so if I think I have 50, I really could have 40 or 60 or 30. If one tries to maintain a higher CYA, how far off could it be?
    Will it be more accurate for me, I have no idea, I will have to try it and see, and even then I really don't know if the numbers I would get would be right......may be just a peace of mind thing.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,103
    I have a trick for you to try. Put the 50% standard in the tube, to the 50% point. Walk around the house and yard until you can't see the dot. That place is where you need to go to read your pool CYA. Problem solved? I know that's what I would do.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Jun 2015
    Glendale, AZ
    156
    Quote Originally Posted by pabeader View Post
    If you want it to be 50 good for you....I get 30
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,103
    But isn't that the point? The 50% is 50% not some arbitrary value. It is a known in this equation. The unknown is your ability to read it for 50% so adjust the variables to get 50% the variables are height above tube. direction of windows in tube. lighting. Adjust those until you get 50%.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,103
    Another way to think of it is this. I have a paint chip. It is Pantone #032c RED If you are in a place that has bluish light what color would you see? Does that mean the chip is not Pantone #032c RED? No. It just means you aren't in the right place to see it properly.
    Mar 2007
    San Rafael, CA USA
    12,082
    The 4088 Taylor tube has a slider dot in it and is not the same as used in the Taylor K-1720 that uses the 9193 Taylor tube that is the same as used in the TFTestkits TF-100 (and TF-50 and individual CYA test kits). While the slider is a nice idea, it's very easy to simply pour the mixture from the tube back into the bottle to repeat the test.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Also, sliders are just as tricky as dots...sometimes more so, because you can still trick yourself into thinking that you see the slider target.
    Essential Links:
    Jun 2015
    Glendale, AZ
    156
    Quote Originally Posted by oldguy70 View Post
    Thanks
    FWIW info....I found the answer to my question, the Taylor #4088 CYA Test tube is the same identical test tube used in the Pentair #79 S/N R151226 CYA Test kit.
    Also, the CYA test I did using the Pentair solution gave the same results as the Taylor solution....are the solutions the same, I have no idea.
