Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: Intellichlor Union cracked
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    334
    Part of the union cracked on me tonight. I haven't had time to look it over yet but I'm curious about how to fix it. It looks like the other part of the union is glued onto the pool plumbing and if memory serves me right, I can't easily remove the piece that is cracked. Will I have to cue the union off all together or is there a way to get just the cracked piece back on? Or should I find a way to just seal the crack on the broken piece? Thanks
    http://
    ~15k gallons, 3'-5'-4' Figure 8 Shape In Ground
    Wetedge Satin Matrix Interior (Pebble)
    Paramount In-floor System
    Pentair IntelliFlo VS 3050, Pentair Triton II TR100 Sand Filter
    Pentair Intellichlor IC40 SWG
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Intellichlor Union cracked
    I'm afraid you can't repair the broken Union by sealing it in place. I would look to replacing it, but it will be a pain. It's beyond comprehension why these systems are never installed with a repair in mind, but it seems standard. You may have to make a few cuts unfortunately, or perhaps just one on the downstream side of this elbow we see part of where you might have room to work with. Remove that section, including Union, and come back in with a new identical piece to mate it up. That would be my first approach based on what I can see here.
    Essential Links:
    Dec 2009
    Central Massachusetts
    2,690
    How much pipe do you have on the other side of the ell? If you could take another picture so we could see that pipe run, it would help us tell you what fittings you'll need.
    Patrick is right. Order another union, cut the ell out and replumb it. You'll most likely need a coupling, a short piece of PVC pipe, and another ell, maybe a street ell, but i need to see the rest of that pipe.
    It's not a hard fix, really.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    334
    Hey guys, attached in another photo showing more of the setup
    A new union, (2) 2" 90s and some 2" schedule 40 pvc pipe and the repair is fairly easy.
    Support the site
    Dec 2009
    2,690
    And one 2" coupling and you're good to go
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    334
    So I just attach every piece with solvent cement?
    Yes. Check a few youtube videos on gluing pvc. The pipe looks painted, so you'll need to clean off the paint where you need to glue.
    Support the site
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    334
    Thanks for the advice. The unions came in the mail the other day and I've been putting off fixing it until who knows when, but the thing is finally leaking on me so it's off to Lowe's to get me some pipe and do this.
    Jul 2014
    Sacramento, CA
    241
    Quote Originally Posted by JamesW View Post
    Is it painted, or naturally that color (CPVC? If so make sure you use the right glue)? If painted, acetone is good for cleaning off some paints, I soak a paper towel and keep rubbing it around the pipe hard until the paint is gone from the area I need to glue to. All the while cursing the previous owner (yeah, there are good reasons to paint PVC for sun protection, but it's still a royal pain to clean off later).
    21000gal IG plaster, Sacramento CA area (late 1950s/early 60s)
    Filter: Cartridge, Pentair CCP420 (2014)
    Main pump: Pentair IntelliFlo VS (2015)
    Boost pump: 3/4hp (2011), Polaris 280 cleaner (unknown age)
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    334
    I'm no plumbing expert but I believe it's just painted and regular pvc?
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    334
    I got all the supplies you guys recommended.... I'm curious about cutting placements. See my pic attached. I believe your advice to cut in one place, but I'm curious if I can cut a bit closer to the area that needed fix?
    I would cut off the whole end by cutting flush with the 90s. Then, I would replace the union nut. And then I would use (2) 90s to make a new end and glue the new end on.
    Support the site
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    334
    Phase 1 complete!
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    334
    I got everything hooked up. I have a very slight drip (maybe once every minute or so) at the coupling between two of my straight pipes. Any cause for worry?
    A drip indicates some weakness in the joint. I would redo it.
    Support the site
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    334
    That's what I was afraid of. How do I redo it all? Do I have to cut the longer pipe further down the line and now add two couplers?
    Dec 2009
    2,690
    Quote Originally Posted by Modawg2k View Post
    You can do that or get a 2" repair coupling. This video shows how to do it. The one shown here is a smaller pipe, but the idea is the same.
    How to Repair PVC: The Slip Fix Fitting - YouTube
    Is the leak between the old PVC pipe and the coupling?
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    334
    The leak is at the coupling/new pipe. May be hard to tell from the photo but to line up everything the old pipe and new pipe weren't the straightest. Maybe that force at the junction is causing the leak
  20. Back To Top    #20
    Jul 2014
    Sacramento, CA
    241
    How did it go? My (very limited) PVC experience is that the following are important to getting a good final seal:
    - Cleaning the pipe beforehand, including making sure all traces of paint are gone.
    - Using plenty of primer and glue per instructions (my glue and primer say to apply to the pipe, the fitting, then the pipe again). Make sure it evenly covers the whole joint area.
    - Pushing the pieces all the way in (you can't dry fit PVC all the way together, so I often measure to be sure I'm cutting the pipe to the right length to go to the stop. Then I measure and cut again when I realize I compensated the wrong way . Mark the pipe where it should go in if necessary. Twisting the pipes 1/4 turn as you put them together is suggested, but obviously not always possible for those last connections.
    The pipes not being parallel is not ideal, but if you do the above it should be able to handle some tension. The only other way I know to address it requires another elbow (basically, angle the middle pipe down, then elbow up and back to the level of the SWCG. The middle elbow would allow the slight rotation needed). But your pipes are close enough that probably isn't necessary if you make a good joint.
