Results 1 to 8 of 8
Thread: Hayward pump runs, cuts off, then won't run
    Sep 2014
    Wharton County, Texas
    32
    Our pump is a TriStar Variable Speed 1.85 hp pump.
    My wife called me yesterday and said there was a 66 error on our Hayward OnCommand controller and the main circulation pump wasn't running and appeared it lost prime. She cut the power off for a few minutes and then it cleared up. Today she calls me and the main circulation pump was cutting on, running for a bit then cutting off. When I got home, I saw a VSC Err: 70. I was able to let it run on low speed for a while, but it would not run on high speed without cutting off. It ran on low speed for a while before it shut off. I checked voltage and there is 240v, even when the water feature pump was running so voltage is now being drawn down.
    I can't find an explanation of that error anywhere. All other functions work off of the PS4 such as the water feature pump, the blower for the spa, etc.
    When I turn the filter on, I hear a clicking on the heater, the display cuts on the heater, but the pump doesn't click or come on.
    Anyone ever experience this? Thank you in advance.
    19K gallon free-formed w/ 60% Color Quartz plaster
    3.5' x 5.5' x 4' depths - 15' x 20' 15' widths - 12" oval raised spa with spillover
    Hayward 1.85 hp TriStar VS Pool & 1.25 hp water feature pump - Cartridge Filter
    Hayward OnCommand automation system - 400K BTU heater - LED lights for pool & spa
    20' weeping moss rock wall - 5' x 8' tanning ledge with bubbler
    Mar 2015
    Cantonment, FL (Pensacola Area)
    380
    Re: Hayward pump runs, cuts off, then won't run
    Way over my head on where the problem may be, but since this is sitting here until someone has seen it or with more knowledge...
    Have you tried removing the COMM connection between the VSP and the PS4 to see if the pump runs ok with its own settings?
    Scott
    15,000 Gallons vinyl in-ground screen enclosed, Hayward Eco-star SP3400VSP, Hayward Aqua Logic PL-Plus, Hayward T-15 Salt Cell, Hayward S244T Sand Filter, Polaris 380 with booster pump, Hayward heat pump HP50HA. K-2006 kit.
    Sep 2014
    32
    When in use with an OnCommand, they remove the control panel on the motor itself since it's controller by the automation. I've spoken to the PB and they are supposed to create a ticket for repair.
    I have been running our water feature pump periodically just to keep the water circulating. The bad part was it took 3 days to actually get a hold of someone to get the issue resolved. Hopefully they can make it out there soon as I don't want my water chemistry to get messed up.
    Mar 2015
    380
    Well, that's stinky They didn't even leave it with you so you could put it back on if needed? You're model could also be entirely different, but my Pro Logic also disables most on-board controls but the Pause/Resume still works and the display still works to quickly see speed and power usage and more detailed errors. I searched for the VSC err:XX and it's an error relaying an error from the pump itself though so it looks like COMM is working and the pump itself likely does have a problem.
    Scott
    Sep 2014
    32
    I talked to the PB and they said the code isn't something I can fix on my end. I suppose it's something within the motor itself.
    I've been running our water feature pump just to circulate the water some.
    Sep 2014
    32
    Yea, where the controller would be is a blank plate so the display is completely gone.
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    426
    If you need more help from Hayward please call 908-355-7995
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    poolside@haywardnet.com
    Sep 2014
    32
    The PB service replaced the pump. My wife later said she got a VSC error of 65 or 66 (she can't remember) even after replacement. She called the PB service guy and said they've been getting the error but cutting it off for 5-6 minutes will clear it out. We'll see tomorrow morning. Thanks for the phone number. I may should have just called there right away.
