Thread: CYA Question
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    CYA Question
    I finally got my water high enough to run the filter. I tied my sock full of CYA near the return. Being that I just got the pump running, I don't want to run it overnight in case there is a problem. Calling for storms tomorrow. Is it safe to leave the sock hanging without the pump running? It's an intex ultra frame. Only a small portion of the sock hits against the liner.
    Jul 2015
    venice, fl
    4
    Re: CYA Question
    Chadrobertc@gmail is cyanuric acid. I wouldn't leave it leaning against any surface, even with the pump on.
    Jul 2015
    venice, fl
    4
    Re: CYA Question
    Quote Originally Posted by Sub-trop-tech View Post
    Sent from my QMV7B using Tapatalk
    Sorry, auto correct. Cya is cyanuric acid.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Re: CYA Question
    Went out and made something to hang it on. Still want to make sure it's okay without the pump on.
    I must admit, this is my first time using the CYA, even though I've been using the TFP method a few years. In my 18' pool, I just used powdered shock until I reached my target,due to the smaller pool size. New things make me nervous, ha ha.
    A pic of how I used my brush to hang the sock: (it's in there good, shouldn't fall)
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,968
    Re: CYA Question
    Excellent idea! Very ingenious. Two
