Results 1 to 14 of 14
Thread: Cal hypo sediment?
    morzh's Avatar
    Jul 2015
    Jackson, NJ
    238
    Cal hypo sediment?
    As I told in "high chlorine" thread I shocked the pool with Cal hypo yesterday. (a turtle visited me so needed to sanitize).
    To refresh, I have high CYA (95) so my chlorine is high and is 6.5ppm, not going anywhere though I stopped adding it.
    I used three packs of 1lb of 76% of Cal hypo.
    I ran the pump and broadcasted the most of it over the deep end, and very little over the shallower part.
    While running the pump, after an hour though it was dark, I noticed sediment at the bottom.
    I brushed it, ran the pump some more and eventually stopped it.
    Today after work I saw a lot of sediment (large white crystals) on the pool floor. All over, especially in creases, but also lots on the flat part and the slopes.
    I took the brush and gave the pool a good swish. After an hour or so very little came back, mostly in corners.
    Why is it? I never had cal hypo not fully dissolve in my above ground that was nit even that deep.
    JoyfulNoise's Avatar
    May 2015
    13,255
    Re: Cal hypo sediment?
    Do you have a full set of water test parameters from before adding the CalHypo? CalHypo is know to cause temporary water cloudiness from the formation of calcium carbonate. Depending on the condition of your water prior to adding the 3lbs of CalHypo, you could have easily scaled out calcium carbonate.
    Matt
    morzh's Avatar
    Jul 2015
    Jackson, NJ
    238
    My calcium was at about 180.
    Fc=TC=6.6ppm.
    pH=7.8-8.0
    TA=110
    I had no cloudiness. Most of the sediment after brushing disappeared, this morning a bit came back, I brushed it again..
    It is not a problem (or I think it not to be) just want to know why.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Chlorine of 6.5 is not high for cya of 95. The target level chlorine for CYA of 95 is 12. And it should never drop below the minimum of 7. Chlorine CYA Chart
    PH needs to be kept between 7.2 and 7.8
    morzh's Avatar
    Jul 2015
    Jackson, NJ
    238
    Yes. And how does it explain the sediment?
    As for the FC it stays put two days after I shocked and is where it was before the shock. In other words it barely dissipates and probably does not get spent. The min is 7 and 6.6 is pretty close, might be 7 in fact, I am guessing by the color as it is off the scale with max of 5. And --- I haven't added any in these 2.5 days.
    May 2015
    13,255
    Without knowing more details about your pool, here's my best explanation -
    The cal-hypo you use is a mixture of calcium hypochlorite, calcium hydroxide and some calcium carbonate. For every 10ppm of FC added by cal-hypo, you add 7ppm to CH. So, when you dump the powder into the water, you locally get very high pH and very high CH until the powder dissolves. This is why it is very advisable to brush vigorously when adding cal hypo to ensure good mixing. With locally high pH and CH, you get scaling of calcium carbonate that will, over time, be redissolved into the pool water but can look like sediment. This is why large doses of cal-hypo can often make water look very cloudy at first. Even if you try to dissolve an appreciable amount of cal-hypo in a 5 gallon pail, the resulting water mixture will look very milky.
    Matt
    morzh's Avatar
    Jul 2015
    Jackson, NJ
    238
    Anything calcium looks murky when dissolved, and heats up too.
    I had to add calcium before, predissolving it in a bucket, it was like milk and very hot.
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    654
    Quote Originally Posted by morzh View Post
    Please be very careful. The test you describe is for Total Chlorine, which includes FC and CC. If CC is present, your FC could be significantly lower than you think.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    morzh's Avatar
    Jul 2015
    Jackson, NJ
    238
    No, CC is not present. TC=FC, as I said.
    morzh's Avatar
    Jul 2015
    Jackson, NJ
    238
    Well, I solved it fairly simply for the remainder of it. I put the cleaner in yesterday in the evening and let it vacuum the whole thing. As it vacuumed, the thing being soluble, it probably mostly dissolved. There is no sediment anymore, the water is sparkling.
    Mar 2007
    San Rafael, CA USA
    12,082
    Excellent. It will dissolve faster after getting sucked up into the bag and getting flow to it. Just sitting on the floor there is very little water flow unless you have a return pointed in that direction.
    morzh's Avatar
    Jul 2015
    Jackson, NJ
    238
    It was not a lot left but it is almost exponential process so every time I brushed portion of it would come back so the robot helped.
    Seasonal World rectangular pool, 27K gallons (data sheet), 25.3K calculated
    Jandy Stealth JHPU 2.0 PUMP, 2HP
    Jandy CL340 cartridge filter
    Pentair C320 inline chlorinator
    AquaComfort heatpump heater
    30,432
    This thread is an example of making things more complicated than they really are. The answer was simple.....the Cal Hypo was undissolved.
    Physical movement (circulating water around it via the robot) was all that was needed to get it dissolved and into the pool water as chlorine.
    Obviously, I am in possession of 20-20 hindsight but we should take away a couple of things.
    1. Always look for the simplest explanation.....it seems like it is most often the correct answer
    2. None of the other chlorine products are as good as liquid chlorine......they all have side effects.
    morzh's Avatar
    Jul 2015
    Jackson, NJ
    238
    This is how it looks now (and has been since I opened it 4 weeks ago).
