I own a soft sided 12' x 30" round Intex Easy Set above ground pool.
The 1,000 GPH pump I use with it in connection with the Intex Solar Mat Heater is woefully inadequate and gives horrible flow.
I have a couple of fairly local options:
SandPRO .5 horse pump and filter...
http://www.poolsuppliescanada.ca/sandpro-0.5-hp-pump-and-filter-combo.html
SandPRO .25 horse pump and filter...
http://www.poolsuppliescanada.ca/sandpro-0.25-hp-pump-and-filter-combo.html
Would the .5 horse be worth the extra money? Can either operate a vacuum properly? Would either be able to work for a larger pool at some point? (i.e. a 18x9x52").
Thanks!
Thanks!
