Thread: How Long Should My SLAM Take
    Jul 2015
    Acworth GA
    1
    My pool is in the blue cloudy post SLAM stage now. Any estimates of how long it should take to clear? Thanks!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: I think I've fought off the algae, but I have a filter question...
    Quote Originally Posted by Stperry99 View Post
    No time limits, each pool is different. Please start a new thread and tell us about your situation.
    Essential Links:
    May 2015
    Macomb, MI
    14
    Definitely take the advice to start your own thread. I can tell you, I'm in the blue cloudy stage and it appears to have no end in sight. I can actually slightly see the brush when I put it to the floor in the shallow end of the pool now. I have been at it since June 27th or 28th.
    16x32 IG Vinyl 22K gal, Tagelus Deluxe High Rate Sand Filter TA-60D, Jacuzzi Magnum Force 1MF-S pump, Hayward CL-200 Chlorine Feeder (NOT in use), Raypak RP 2100 Heater
    , K-2006 test kit
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: How Long Should My SLAM Take
    If you are cloudy you are NOT post SLAM, you are still in the SLAM
    Keep the pump running
    Brush once a day
    Keep FC at shock level
    Support the site
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    It all depends on the effiency of your pump and how often you dose your chlorine to SLAM level. If it frequently falls below slam target, it takes longer. Brushing and vacuuming often can speed things up. Scrubbing hiding places like lights and ladders can also keep it from stalling.
