Thread: Show me more....
    Jun 2015
    Mattawan, MI
    2
    Show me more....
    I love to read and learn, but I can't seem to see everything here. For example, this help forum says it's got over 400 threads, but when I click, I only have two pages. Where are the other 18 pages? Am I missing a setting somewhere?
    May 2015
    Chicago, IL
    508
    Re: Show me more....
    Scroll down to the bottom, and there is a drop down where you can select a timeframe, Where it says, Show thread from...
    Select beginning.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    The default is two weeks, If you want to go further back, scroll down and change the settings as mentioned above.
    May 2015
    Chicago, IL
    508
    Which I have no idea why it is set up like that, it should be beginning by default.
    Jun 2015
    Mattawan, MI
    2
    Quote Originally Posted by ozzy47 View Post
    Select beginning.
    Bingo! Wow. That should be a default. Thanks Ozzy.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Now you've got some reading to do!
